Sponsored by: Auxito
2002 5.4 Coolant Operating Temp
Old Dec 29, 2014 | 07:18 AM
IndyFan's Avatar
IndyFan
What should I be seeing? I've got the Torque app on my phone and a Bluetooth transmitter hooked into the OBD II port and it shows it typically at 176 to 180 degrees, with a max of 185. Is this right, or should I be replacing the thermostat? What should normal operating coolant temp be?
Thanks!
Old Dec 29, 2014 | 08:43 AM
Spotty's Avatar
Spotty
LOL....I'm WAAAAY too old to understand what you are doing. Old school....what does the gauge read when it is fully warmed up and how hot does the heat blow?
Old Dec 29, 2014 | 02:02 PM
IndyFan's Avatar
IndyFan
The guage is really a glorified idiot light with no numbers on it, just a C and H for cold and hot, respectively. It shows just below the halfway mark when fully up to operating temperature. The Torque app gets its data straight from the engine computer, which gets it from a sensor. The heat gets warm, but it is just adequate. It never gets hot.
My Jeep, on the other hand, gets hot enough to run you out, even with a soft top on in the middle of winter, but it's heat is hotter than Mos other vehicles, anyway.
I'll get and post data for it and my other vehicles and will post it. I'm thinking I'll see something north of 190 degrees.
Old Dec 29, 2014 | 03:32 PM
Spotty's Avatar
Spotty
The gauge is accurate for the most part. Slightly below half is correct. If you put in a cooler thermostat you would see the gauge reflect lower at full warm up.....I have done it. As far as the heat goes, how do the hoses feel going into the heater core....both nice and hot....both just warm.....or one a different temp. than the other..?
Old Dec 29, 2014 | 04:11 PM
IndyFan's Avatar
IndyFan
I'll check them and check back.
Old Dec 30, 2014 | 08:29 AM
IndyFan's Avatar
IndyFan
My Mercedes was in the same temp range, so maybe it is fine. I'll be checking heater core hoses next.
Old Dec 30, 2014 | 11:56 AM
Bluegrass 7's Avatar
Bluegrass 7
The correct full temperature range is 195 +/- 5.
Good luck.
Old Dec 30, 2014 | 02:24 PM
IndyFan's Avatar
IndyFan
Good luck.
Then I think a thermostat change is in order.
Thanks Bluegrass and everyone else!
scottswierenga
Dec 7, 2013 07:08 PM
cam_12484
2004 - 2008 F150
Dec 8, 2009 07:46 PM
Texascadillac42
Dec 21, 2008 07:23 PM
apropos
Nov 9, 2004 09:08 PM
Minimal_Subset
1966 - 1977 Early Broncos
Oct 10, 2004 01:37 PM
