Strange Thermostat behavior
Old Nov 8, 2004 | 08:10 AM
apropos's Avatar
apropos
1990 F250HD
The temp gauge was always reading cold. So I thought the T-stat went bad in the open position. I got a new OEM (Motorcraft) Thermostat, 195F and installed it. Very slight change, the temperature gauge moves a little bit but never gets in the "operating range".
I recall it wasn't doing that last year. But my heater works well....
So I think it's something else. Could it be some sensor, like coolant temperature sensor?
Old Nov 8, 2004 | 07:08 PM
Pikachu's Avatar
Pikachu
Could certainly be the temperature sender or guage. Warm it up and check the temperature with a candy thermometer, or an infrared heat heat gun. That will certainly be more accurate than the "idiot-light-on-a-stick" guage.
Old Nov 9, 2004 | 09:08 PM
apropos's Avatar
apropos
The temp. seems right. The heater hoze is certainly very hot, so it seems the T-stat is opening all right. and I think so did the old one.
