Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Levelling
Old Dec 28, 2014 | 11:56 PM
Cas1's Avatar
Cas1
Levelling
Hey All;
Can anyone tell me if you can use 2 inch blocks on the front of my 78 F-250 (leaf springs) to gain a little space and if so, is there anything anyone would recommend?
Thanks.
Old Dec 29, 2014 | 08:51 AM
96sherm's Avatar
96sherm
Hey Cas1, I'm not the most familiar with those series of trucks, but in a little research it looks like they use a leaf to lift the front... I think adding a block would achieve the same thing, though I would be inclined to add ladder bars for stability, similar to what is done if using a large lift block on the rear of the truck. I'm sure someone with more knowledge than I will chime in.
Welcome to the chapter if you're a local member...
Old Dec 29, 2014 | 09:48 PM
Randy_270's Avatar
Randy_270
I'm fairly certain it is illegal to use blocks on the front of a leaf sprung truck, not only that it's also dangerous. Unless this is a strictly an off road vehicle, I highly advise not to use lift blocks in the front of your truck.
Old Dec 30, 2014 | 06:16 AM
Cas1's Avatar
Cas1
Levelling
I appreciate the input guys and yes I am new. Anyone with more thoughts, please feel free!
Old Dec 30, 2014 | 09:33 AM
96sherm's Avatar
96sherm
Cas1, 4in Suspension Lift Kit for 77.5-79 Ford 4wd F-250 Lowboy Pickup [415.20] | Rough Country Suspension Systems This would probably be the best way to go. I would suspect that a drop shackle bracket would be a better choice than using a block, but the lift in the link for $500 is a pretty good buy, and then its done right.
What part of the country are you in?
Old Dec 30, 2014 | 06:58 PM
Cas1's Avatar
Cas1
Thanks 96Sherm,
I'm in Saskatoon, always open to tips and tricks...Cas.
Old Apr 14, 2015 | 04:03 PM
Cas1's Avatar
Cas1
I decided to go with the rough country 4 inch lift and am currently installing a power lock in the rear diff before completing the install...Thanks!
Old Apr 14, 2015 | 08:44 PM
96sherm's Avatar
96sherm
Good stuff Dude!!! Remember one thing with your modifications...we love pictures!!!!
acf6
Apr 20, 2013 06:09 PM
Mat J
May 5, 2010 07:31 PM
Jeff Dodson
Offroad & 4x4
13
Oct 5, 2008 09:16 PM
ech0sh4y
Offroad & 4x4
Jan 10, 2008 09:12 AM
bigsexy63
Dec 11, 2005 10:00 PM
