f350 idle/fuel problem
Old 12-27-2014, 06:16 PM
godtar02's Avatar
godtar02
godtar02 is offline
1994 f350 dual tanks 460 c.i.
Truck runs fine but dies at idle (blubbers at idle) if I am idling on rear tank and switch to front, truck will blubber (IDLE) worse and die.
Truck seams to run better on rear tank and idles better in drive, or reverse. Drives down the road fine. Cold start at 10 degrees farenheight is perfect, pops right off and goes to fast idle but will then slowly decrease until it idles very rough and might die.
When driving on the road ( 55 mph) on rear tank, truck will run fine. Switch to front tank (55mph) loses some power.
any help will be appreciated.
Doug
Old 12-29-2014, 12:27 PM
daddylee100's Avatar
daddylee100
daddylee100 is offline
Fuel pressure? bad fpr..
Old 12-29-2014, 12:33 PM
David7.3's Avatar
David7.3
David7.3 is offline
I'm thinking the pump in the tank is shot or the sock is clogged and or fuel contaminated. the main pump on the frame works fine, the rear tank is ok, it seams the front tank has an issue, when you check it out changed the fuel filter to. quick test is to install a fuel pressure tester in the port on the fuel rail. Run it and swap tanks see if you loose pressure if not, must have some crap in the tank.
Old 12-29-2014, 12:50 PM
daddylee100
These trucks have in tank pumps. They stopped the frame pump in the 91-92 model junp
Old 12-29-2014, 01:24 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,194 Likes on 943 Posts
1990 was the first year with the high pressure in-tank pumps for gas powered F-series trucks.
Old 12-29-2014, 01:26 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
Sounds like a bad fuel pump and or a dirt fuel filter. A bad fpr would have the same result on both tanks.
Old 12-29-2014, 02:51 PM
godtar02's Avatar
godtar02
godtar02 is offline
idle /tank problems
I think I am going to check fuel pressure and also change fuel filter (i have never changed it) if that does not work I will change IAC. remember this is pre obd2 and is not triggering a check engine light.
I will keep you updated may be a few days it is cold here in MInnesota
Doug
Old 12-29-2014, 02:55 PM
daddylee100
IAC is only for keeping an idle. That wouldn't have anything to do with a bog, especially at highways speeds or light throttle applied.
Old 12-29-2014, 02:56 PM
rla2005's Avatar
rla2005
rla2005 is offline
Doug
Fully aware this is an OBD-I truck. Many times there can be a stored code or issue that would cause a KOEO test failure code without having an active Check Engine Light.
Crewcabber's Avatar
Crewcabber
OBD1 OR OBD2 doesn't matter they both have check engine lights.
Old 12-29-2014, 03:04 PM
Crewcabber's Avatar
Crewcabber
My 97 cclb 460 e4od is an OBD1 truck
Old 12-29-2014, 03:11 PM
daddylee100
And everybody and their momma has argued with you about it ^^ lol
Old 12-29-2014, 03:17 PM
Crewcabber's Avatar
Crewcabber
/\/\/\/\ yes sir they have/\/\/\/\/\. I was waiting for somebody to tell me I'm wrong again. Hey aren't you supposed to be working?
Old 12-29-2014, 03:28 PM
daddylee100
I am working lol. Aren't you? Haha. Just browsing the forums.
Old 12-29-2014, 03:42 PM
Crewcabber's Avatar
Crewcabber
No I'm off the Boy's are out of school and the baby sitter fell thru.
EgoTrip90
04-24-2015 07:44 AM
cjdmcgarry
08-25-2014 10:11 PM
thewellman
01-31-2012 06:16 AM
FSSF
10-17-2008 11:16 AM
gravedigger
04-22-2005 08:25 PM
Quick Reply: f350 idle/fuel problem
