Misfire with no codes
Old Dec 27, 2014 | 01:01 PM
teamlx88's Avatar
teamlx88
I have a 98 Expy with 128k on it and it is having misfire issues with no CEL or codes pending. When the truck is cold it runs fine but after it warms up and is shut off the problem comes on restart. There is a obvious misfire when under load like when going up a hill. The truck won't rev and starts breaking up. Level road driving isn't bad.
The fuel pump and filter are new and the plugs are only a year old. Fuel pressure is 40 psi with vacuum off and scanner shows fuel trims are spot on. Coils are only 2 years old and I think that's the problem(not good quality). TPS was also changed. Truck has no vacuum leaks either. What could it be besides coils? I really don't want to buy another set just to find out that's not the problem
Old Dec 27, 2014 | 05:35 PM
projectSHO89's Avatar
projectSHO89
Scan tool, Mode $06, PID $51 or $53, check misfire counts.
Old Dec 28, 2014 | 01:40 AM
teamlx88's Avatar
teamlx88
Thank you. I'll start there
BigBashy25
Jan 14, 2018 02:47 PM
cyleaverett
Dec 23, 2014 01:53 PM
wampumbiskit
3.8 & 4.2L V6
Feb 5, 2014 08:20 AM
brc777
Jun 9, 2011 04:34 PM
PhinPhan
1983 - 2012 Ranger & B-Series
Aug 3, 2004 04:57 PM
