A Question
Old Dec 27, 2014 | 12:18 PM
MJD's Avatar
MJD
A Question
1994 Ford F350 Crew Cab Flatbed
Did this thing come from the factory that way, or was it a single wheel. I usually only see 4X4 duallys of this era in a single cab config. Thanks!
Old Dec 27, 2014 | 01:34 PM
'89F2urd's Avatar
'89F2urd
Coulda been factory. I've seen 4x4 crew drw. I've seen a good amount of dump and stake body crew drw 4x4. Maybe they sold a lot of cab n chassis also....
Old Dec 27, 2014 | 02:01 PM
Fastback460's Avatar
Fastback460
As far as I know these trucks never came from the factory with drw and 4x4, it was always one or the other.
It's either a dually converted to 4x4, or vice versa.
Old Dec 27, 2014 | 02:30 PM
Diesel_Brad's Avatar
Diesel_Brad
The ONLY way to get a 4wd dually from the factory was as a cab-n-chassis. ANY 4wd Dually PICKUPS you have seen have been converted.
As for the Craigs List ad, hard to say if a cab-n-chassis or pickup. Easiest way to tell is door jam sticker. But I am going to say SRW truck converted to dually and a flatbed was added.
Pickup will have...
10k GVW for dually pickup
9K GVW for SRW pickup
164" Wheel base for Pickup
3" rear leaf springs for pickup
Cab-n-chassis will have
11,000 GVW for cab-n-chassis
161" wheel base for cab-n-chassis(never seen a factory 4 door cab-n-chassis)
2.25" rear leaf spings
Old Dec 27, 2014 | 07:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
an even easier way to tell is this: C/C trucks have a 33 inch wide frame. pickups have a 36 inch wide frame.
so if the rear frame rails are 33 inches wide, it is probably factory.
if the rear rails are 36 inches wide, it was made into a 4X4 dually.
Old Dec 27, 2014 | 10:34 PM
MJD's Avatar
MJD
Thanks guys. Not real important, but I have always wondered.
Old Dec 28, 2014 | 08:32 AM
Diesel_Brad
Originally Posted by tjc transport
an even easier way to tell is this: C/C trucks have a 34 inch wide frame. pickups have a 36 inch wide frame.
so if the rear frame rails are 34 inches wide, it is probably factory.
I fixed your typos tom
Old Dec 28, 2014 | 10:10 AM
'89F2urd's Avatar
'89F2urd
some encyclopedias around here. . .
Old Dec 28, 2014 | 10:20 AM
tjc transport
i ain't rite
mehhhh. 33-34. i am old and senile, cut me some slack, will ya?
John Buck
13
May 15, 2018 03:28 PM
GM4WALLS
39
Sep 9, 2014 04:08 AM
southtexasidi
13
May 18, 2014 05:19 PM
Vinford
Jan 8, 2014 08:33 PM
rbroadster
Apr 14, 2003 11:29 AM
