4inch exhaust install
Old Dec 26, 2014 | 10:50 PM
sand1's Avatar
sand1
How difficult is it to do a turbo back straight pipe kit 4inches and about how long does it take I did a couple on my 7.3s and were fairly easy but haven't did one on a 6,0 yet my truck is a 06
Old Dec 26, 2014 | 11:23 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
If the kit has a 3.5" down pipe, a couple of hours. I've heard that a 4" down requires additional bad language, liquid refreshments, and a hammer...
Old Dec 26, 2014 | 11:30 PM
Pete_H's Avatar
Pete_H
I/ agree, 3.5 downpipe = about 2- 2.5 hours in and out. having another set of hands to get the alignment correct would be very helpful.
Old Dec 26, 2014 | 11:41 PM
87crewdually's Avatar
87crewdually
If you're doing this on the ground you will most likely have to cut the old down pipe to get it out.
Old Dec 26, 2014 | 11:44 PM
sand1's Avatar
sand1
I'll definitely be on the ground doing this so what has to be finessed if a 4 . Inch dp is being used
Old Dec 27, 2014 | 01:27 AM
MisterCMK's Avatar
MisterCMK
The firewall. The 4" downpipe is pointless
Sent from my mind thanks to the Internet and an app.
Old Dec 27, 2014 | 01:38 AM
sand1's Avatar
sand1
$o what size is the stock dp
Old Dec 27, 2014 | 08:10 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
IIRC, the stock DP is 3", and from the cat back is 3.5".
You will either be persuading (with a hammer) the firewall as mentioned or the pipe. Not worth the effort IMO. The MBRP 4" TB system I bought came with the 3.5 DP. I don't remember there being an option to get a 4" instead...
Old Dec 27, 2014 | 11:29 AM
92will's Avatar
92will
I bought magnaflow 4" turbo back system with muffler and car delete. I haven't installed it yet. Was actually going to this weekend, but been pretty lazy so will get to it in the next few weeks. I think my down pipe is 4" but now I'm not sure. I have heard it is a pain, but doable. I just want to keep EGT's down while towing 12k fifth wheel.
When are you doing yours?
Old Dec 27, 2014 | 11:34 AM
92will's Avatar
92will
I just looked and my down pipe is 4". whoo hoo!! sounds like fun. There is a flat spot on part of the down pipe. Maybe it was put there to help, I don't know. I knew the down pipe was going to be the biggest problem by far, especially doing it on the ground and by myself. I will get the wife or one of the kids to help with that part though.
What part of the firewall needs to be massaged? What part to avoid?
Old Dec 27, 2014 | 11:36 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Originally Posted by 92will
I bought magnaflow 4" turbo back system with muffler and car delete. I haven't installed it yet. I think my down pipe is 4" but now I'm not sure.
The PO of my brothers truck installed a 4" Magnaflow system, it actually has the 4" DP. So yours very well could be as well.They chose to hammer on the pipe instead of the FW.
Old Dec 27, 2014 | 12:47 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
4" down pipe is also too big if you have a ZF6...
That takes a lot of hammer.
Old Dec 27, 2014 | 01:13 PM
92will's Avatar
92will
Im of the school of thought that if you have a 3.5" downpipe, you might as well have 3.5" all the way. Not true? Seems like a bottle neck is a bottle neck. How can 4" out the back flow more than the 3.5" down pipe?
Old Dec 27, 2014 | 03:59 PM
sand1's Avatar
sand1
I may jus buy the cat delete pipe and take the muffler off and leave the rest stock
Old Dec 27, 2014 | 08:01 PM
MisterCMK's Avatar
MisterCMK
Not true. You are forgetting that exhaust velocity changes as you get further from the turbo.
Sent from my Telegraph using IB AutoGroup
