1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Intermittent starting problem... Help a Vet out...
Old 12-26-2014, 09:32 PM
mstein86's Avatar
mstein86
mstein86 is offline
Vehicle is a 1999 expedition 5.4L, on occasion the vehicle won't start, it wont even turn over. I have to pop the hood and jump the starter relay on the fire wall and then it runs. I had the starter checked and it was good, the starter relay on the fire wall is also new and I also replaced the battery cable harness. I'm thinking its the ignition switch but not 100% sure. Any ideas?
Old 12-26-2014, 09:37 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Do you have slop in the shifter ? You may have an issue with not going into park properly . The neutral safety switch may be faulty also . Just a few thoughts ...
Old 12-26-2014, 10:29 PM
mstein86's Avatar
mstein86
mstein86 is offline
If that's the case I should be able to put it in neutral when it doesn't start to start the vehicle?
Old 12-26-2014, 10:39 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Possible . Try neutral and such . Look at the base of the column where the shift cable attaches , see if that bit is loose .
Old 12-27-2014, 07:44 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Check for a sloppy shifter lever first. There's a pair of screws under there that loosen up and cause your issue.
Old 12-27-2014, 11:35 AM
alloro's Avatar
alloro
alloro is offline
Received 4,216 Likes on 2,446 Posts
Yes, or another method is (with your foot on the brake) to reach over with your left hand and hold the key in the start position while moving the shifter down with your right hand until you hear the starter engage.
Old 12-27-2014, 01:24 PM
mstein86's Avatar
mstein86
mstein86 is offline
The neutral safety switch is new, the transmission was just rebuild. The two torx screws are tight and this shifter doesn't have any slope in it.
Old 12-27-2014, 05:31 PM
projectSHO89
Check fuse F21 with a test lamp with the keyswitch in START. That fuse should go hot in that switch position.
F21 is in the circuit that includes the DTR switch between the ignition switch and the starter relay under the hood.
Old 12-28-2014, 02:04 AM
alloro's Avatar
alloro
alloro is offline
In that case you could be looking at a worn ignition switch, just as you suspected earlier.
Fraalan
1999 to 2016 Super Duty
04-14-2015 07:26 PM
bolo789
10-07-2010 11:19 AM
7.3 Enthusiast
05-05-2010 07:33 PM
dyna
02-02-2010 08:39 AM
Monsta
02-02-2003 07:50 AM
Quick Reply: Intermittent starting problem... Help a Vet out...
