Heater hose
Old Dec 26, 2014 | 07:30 PM
hanklin's Avatar
hanklin
Heater hose
Heater hose blew at firewall on Christmas morning and am wondering how far I can drive in this condition. Antifreeze dropped and it is hose on drivers side. Choices are this, drive 2 miles to shop or call AAA and tow it. Towing would be at like 3am as I leave for work and have someone wake up with a flatbed. What ya guys think? I`m thinking tow but,,,,,,,,,,
Old Dec 26, 2014 | 07:31 PM
hanklin's Avatar
hanklin
Btw truck is at home nice an safe not stuck on road
Old Dec 26, 2014 | 07:36 PM
M-S-G's Avatar
M-S-G
Is it spewing water? It might when the thermostat opens.
I doubt it will open in 2 miles.
I would wait for it to cool down and drive. 2 miles is barely enough to get it up to operating temp.
If it was mine I would drive it. NO revving.
Old Dec 26, 2014 | 07:38 PM
hanklin's Avatar
hanklin
Yes its the heater core hose and son got back after drive the 1/2 hour latrer I went to move and thats when she blew. So you are saying fill rad and go?
Old Dec 26, 2014 | 07:43 PM
The Brad's Avatar
The Brad
Plug the heater hoses off and drive as long as you want. Normally 2 miles wont get it up to temp, but coolant is always flowing through those hoses whether or not the tsat is open. A cylinder with no coolant around it will ovrheat before the rest of the block gets to operating temp.
Old Dec 26, 2014 | 07:45 PM
M-S-G's Avatar
M-S-G
I wouldn't even bother. Tstat WILL NOT open in 2 miles.
Do wait for some senior member to chime in. I'm' just 'some guy'.
My only worry would be ruining water pump. That's all.
Pikachu's Avatar
Pikachu
No, don't do that. The coolant circulates through there whether the thermostat is open or closed. If you don't want to have it towed, you can bypass the heater core with a piece of 5/8" hose. Disconnect both heater hoses, one on top of the water pump and the other at the fitting on the right head and connect the piece of 5/8" hose to the 2 open nipples. OR you can clamp off both heater hoses. Fill the coolant back up, and you can drive it indefinitely that way. You won't have heat though.
Old Dec 26, 2014 | 07:46 PM
hanklin's Avatar
hanklin
Plug up the broken hose?
F350-6's Avatar
F350-6
Pull off the other heater hose and put a piece of pipe or nipple to with hose clamps to tie them together. This will bypass your heater, but allow you to drive for as many miles as you wish until you get it fixed.
Old Dec 26, 2014 | 07:48 PM
hanklin's Avatar
hanklin
Gotcha,,Thanks for help
M-S-G's Avatar
M-S-G
I don't think it's the heater core hose though, since OP says drivers side.
If it is heater core, a metal broom stick makes a pro coupler.
Old Dec 26, 2014 | 07:51 PM
M-S-G's Avatar
M-S-G
Sh** I can't read.
It IS heater core
hanklin's Avatar
hanklin
It goes into heater core. They are side by side on firewall. Driver side blew.After 380k miles its about due for both I would guess
Old Dec 26, 2014 | 07:53 PM
M-S-G's Avatar
M-S-G
Go get the broomstick pro-coupler.
Old Dec 26, 2014 | 08:08 PM
F350-6's Avatar
F350-6
I remember when broomsticks used to be solid wood, but for that matter, a solid plug in the lines would work also. The water pump pressure would just divert the flow to the path of least resistance so you don't run the risk of it blowing the plug out from increased pressure.
