Steering colum upper bearing?
Old Dec 26, 2014 | 06:14 PM
351Cleveland C4's Avatar
351Cleveland C4
What is at the top of the column under the steering wheel? A bearing or a bushing? How do you replace it? My steering wheel has started to grind in certain positions.
Old Dec 26, 2014 | 06:32 PM
garbz2's Avatar
garbz2
Upper and lower bearing with a taper sleeve. All available aftermarket.
Garbz
Old Dec 26, 2014 | 06:40 PM
JEFFFAFA's Avatar
JEFFFAFA
2X it's a bearing. C3DZ3517A. Still available from Ford. Note,Earnhardt,Sanderson,and Bell Ford have it in stock. It's been a while but I think they come in a package of three. Sold separately though.
Old Dec 26, 2014 | 06:50 PM
351Cleveland C4
Hard to replace?
Coastal68's Avatar
Coastal68
I think I have the same problem. I hear a grinding sound from the steering column when I turn the wheel at a stop or when driving slowly. Armstrong power steering, BTW.
So, how do you replace it?
Old Dec 26, 2014 | 08:38 PM
D & D's Avatar
D & D
Originally Posted by 351Cleveland C4
Hard to replace?
The bearing itself...no
Just keep the rest of the parts that you have to remove in order and you will be fine.
Old Dec 26, 2014 | 08:57 PM
ultraranger's Avatar
ultraranger
This should help STEER you in the right direction.
http://www.fordification.com/tech/im...ing-column.jpg
Old Dec 26, 2014 | 09:00 PM
crazed87bronco's Avatar
crazed87bronco
It's really easy to do can be done in an afternoon. Here's my 4x4 column but you get the same idea for your top bearing as they are the same but mine uses a different bottom bearing. Your 2wd column uses the same top and bottom bearings part number is C3DZ3517A can be purchased at your ford dealer or a site sponsor
https://www.ford-trucks.com/forums/1...uild-some.html
Old Dec 26, 2014 | 09:49 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper bearing 3517 located in 3511 flange. 3518 is its nylon sleeve, it's also available from Ford (B1AZ-3518-A).
Besides 1961/73 F100/250's & 1967/73 F350's, this C3DZ-3517-A bearing and sleeve were also used in 1966/74 Bronco's & myriad 1960/66 Passenger Cars including 1965/66 Mustang's.
Old Jan 29, 2015 | 08:51 AM
hillcountryflt's Avatar
hillcountryflt
Glad I found this post. It will help me with the rebuild of my steering column.
Already ordered the bearings and retainers.
cr0wjane
Sep 5, 2018 08:20 AM
burnout400m
Nov 18, 2012 02:19 PM
SCRAPHEAP51
Jan 16, 2011 02:29 PM
loserpdenton
Feb 24, 2004 03:09 AM
Ratsmoker
Jan 29, 2004 06:00 AM
