Block Heater
Old Dec 26, 2014 | 04:48 PM
lewis racing's Avatar
lewis racing
Block Heater
Im in Virginia so the winters are not to cold here yet. Was wondering how many of you guy are plugging in your trucks. I use to have it on a timer but I was thinking,, is that thing controlled by a thermostat? Seems like it would be so it wouldn't just get hotter and hotter. thanks.
Old Dec 26, 2014 | 05:01 PM
Forddiesel06's Avatar
Forddiesel06
If and when I do plug in here, I put it on a timer for a couple of hours and my scanguage reads 107*.
Old Dec 26, 2014 | 05:06 PM
2006White60's Avatar
2006White60
I usually try to plan ahead and night before use I plug her in. I don't know why but for some reason I use 25* as a low temp to even to think about it. Right now the high is 15* and the low tonight will be near 0*!! Friggen cold!!
Old Dec 26, 2014 | 05:22 PM
87crewdually's Avatar
87crewdually
To answer your question, no there is not a thermostat to turn it on/off. It has been thought of and used on the plug end for the Duramax if you choose to pay extra for the cold climate package.
Old Dec 26, 2014 | 06:41 PM
F357's Avatar
F357
The heater will only get to about 120 at the most if you leave it plugged in 24/7, cooler in colder weather. If your truck starts in the cold then you don't "need" it. I use mine all the time even though it doesn't get that cold here. It saves a lot of fuel heating up 1000lbs of engine and some 15 gallons of fluids.
Old Dec 26, 2014 | 07:17 PM
WatsonR's Avatar
WatsonR
I live in Virginia as well, plug it when it's in the 30s to 40s range, save's fuel
Old Dec 26, 2014 | 07:19 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I start to plug in when overnight temps reach into the negatives.
And when I do plug in I set the timer for 3-4 hours before start.
I'm not religious about it though, the engine starts down to -10 no problem.
Old Dec 27, 2014 | 09:30 AM
lewis racing
thanks guys
Old Dec 27, 2014 | 11:23 AM
92will's Avatar
92will
It doesn't get real cold here in Tennessee, but I still plug it in just to help with the charging system, and to get heat sooner. I plug mine in all night, usually about 9 hours. I have seen temps at 141 degrees when starting it the next morning (coldest so far was about 20). I get instant hear, truck starts like it was just drove, and the stock 110A alternator doesn't have to wear itself out to bring the batteries back up. It costs me 77 cents to run it for 9 hours.
Old Dec 27, 2014 | 12:41 PM
BLADE35's Avatar
BLADE35
ya my truck would start at -10* f sure
But sure is hard on that HPOP
Im convinced it lead to my hpop fail last year this time I wasn't plugging it in
your guys newer style hpop do better Im sure
But since that HPOP fail I plug mine in religiously daily and its on a Timmer
Old Dec 27, 2014 | 01:35 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Never really thought about this taking place.
Old Dec 27, 2014 | 02:32 PM
Bullitt390's Avatar
Bullitt390
3 degrees this morning and I actually did plug in.
Except the GFCI tripped. D'Oh!
Josh
jiggersup
Nov 30, 2010 06:03 PM
kawa
15
Oct 25, 2009 11:45 PM
Fordfreak1978
16
Feb 19, 2008 08:32 PM
greedy737
Nov 15, 2007 06:38 AM
cbirdman
Feb 14, 2007 11:00 AM
