Wipers will not turn off
Old Dec 26, 2014 | 08:14 AM
cooki715's Avatar
cooki715
I have a 2006 Lincoln Mark LT (Ford F150)- I recently had my wipers turn on automatically, and they will not turn off. I removed the key from the ingition and they still continued to run. I removed both fuses listed in the owners manual listed for the wipers, and they still keep running. I was getting ready to purchase a new Wiper/Washer switch, but was told it probably would not resolve the issue. I don't want to waste $110 on something i won't be able to return. Any ideas what could be causing this issue?
Old Dec 26, 2014 | 01:47 PM
Greg B's Avatar
Greg B
There is probably a short in the wiring between the switch and motor somewhere. I would unplug the motor and back probe all wires except the hot wire every inch or two starting at the plug and see where you lose power. Ground the voltmeter on a good ground on the body. That's where I would start.
Old Jan 24, 2015 | 03:47 AM
90trunk's Avatar
90trunk
This happened to my 06 SCAB and it ended up being a bad wiper motor.
Old Jan 27, 2015 | 07:37 AM
cooki715's Avatar
cooki715
Thanks for you help, it ended up being the wiper motor. Replaced it this weekend, and I've got my truck back in time for all this snow they're calling for.
GTBksRule
Electrical Systems/Wiring
Feb 9, 2013 08:16 AM
jayrus544
Jun 7, 2010 08:02 PM
Grannygear
1997 - 2003 F150
Jan 10, 2009 12:32 PM
rob1994AerostarAWD
Aerostar
Dec 25, 2008 08:33 AM
Tools32
1997 - 2003 F150
Feb 27, 2006 08:54 PM
