turbo upgrade
Old Dec 30, 2014 | 11:37 AM
1972RedNeck's Avatar
1972RedNeck
Originally Posted by lindstromjd
The Holset is designed to go on an engine topping out at 360 cubic inches.
Not true. Most HX40's came on 8.3 liter Cummins - another 60-ish cubic inches over the 7.3.
Old Dec 31, 2014 | 12:33 AM
hairyboxnoogle's Avatar
hairyboxnoogle
I can only imagine that was in reference to the hx35, which according to holset is suitable for use on 4-5 liter engines.
I assumed 40s were used on 8.3s, but ive only seen the H1E on them.
Old Dec 31, 2014 | 02:04 PM
racer30's Avatar
racer30
The HX40w is found on the 8.3 Cummins in a lot of Motor Homes in the Industry...
With power ratings of 300 to 350 Crank HP. I put a few Banks upgrades on them changing the Hot sides from T4 18cm2's to T417cm2 housings and it uses a 25psi Waste Gate assembly instead of the standard 20psi unit for quicker spool and more boost. The trade off is higher EGT's as long a you have a good Intercooler its a nice upgrade.
Old Dec 31, 2014 | 10:13 PM
Fireman_dave's Avatar
Fireman_dave
Racer...i always go by rwhp because thats what im putting to the ground
Old Jan 1, 2015 | 08:54 PM
Fireman_dave
Have a line on an h1c, for 100 buck, 18.5 cm housing, better than the 093?
Old Jan 2, 2015 | 09:44 AM
hairyboxnoogle
H1C = HX35 with retarded housings. In all honesty, probably a little more flow on the compressor side, but i wouldnt call it an "upgrade". Certainly not worth swapping out the garret, but if piecing together a budget kit.. wouldnt be bad.
dogerbrown1
16
Jan 6, 2022 12:17 AM
Kstar9
38
Jul 15, 2012 10:53 AM
1973dieselhighboy
Feb 22, 2011 09:33 PM
m350
Apr 14, 2007 07:58 AM
marvinlong
Apr 19, 2006 09:16 PM
