Projects For 3D Printing
Old Dec 31, 2014 | 10:32 AM
  #91
Gary Lewis's Avatar
Gary Lewis
Originally Posted by ArdWrknTrk
Yes, that
But also, not too long ago there was a guy who was trying to repower his truck.
In wading through the numbers we determined the M & 400 used diffeerent throwout arms and different pivots inside the belllhousing.
I sent him a pair of flathead black oxide Allen screws to retain it because he couldn't find them.
Ahhh! I remember that. Ok, I understand.
But, one question - how strong are the 3D printed metal parts? The engine/tranny pivot takes a bit of force laterally. Perhaps make just the mount via printing and use a stud/ball combo - like maybe the one for a six?
Old Dec 31, 2014 | 10:45 AM
  #92
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Brass or nickle braze has a lot more tensile strength than cast iron.
It may not wear as well, but the printed parts are a matrix/filler.
You could check the Young's moduls of their material
A little attention and grease go a long way.
Old Dec 31, 2014 | 03:08 PM
  #93
reamer's Avatar
reamer
Gary I could send you the 4" x 7" speaker grills, But I have to get them back. wont be installing them for a few weeks. Was going to try and clean them up the paint, but if you could scan them or what ever....
Old Dec 31, 2014 | 03:24 PM
  #94
Gary Lewis's Avatar
Gary Lewis
Ron - I may have a set, but I can't get out to the shop right now to check. Maybe tomorrow. So hang onto hours for now. However, once I sign up for FabLab I could use their 3D scanner and, assuming the results look good, try to print them. I say "try" because the reading I'm doing suggests that things shaped like they are with long, thin pieces warp easily and may need extra support.
Old Dec 31, 2014 | 03:28 PM
  #95
Gary Lewis's Avatar
Gary Lewis
Jim - Missed your post. If the bracket is strong enough after printing I'd hope to use a stud & ball from another application. That way the wear won't be on the printed part and would be replaceable.
Old Dec 31, 2014 | 05:00 PM
  #96
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ah, I gotcha Gary.
As for pieces warping, that's why Shapeways uses an armature built of dissolving plastic.
To support an object as it is formed.
IDK what FabLab uses as a medium.
Shapeways has thermosetting and UV curing monomers like methacrylate, and they will not sag.
Old Jan 1, 2015 | 03:01 PM
  #97
Gary Lewis's Avatar
Gary Lewis
Jim - FabLab doesn't print metal, unless I missed something. But I'll probably contact Shapeways if I get a sample to model to find out what they see the strongest of their products as well as methods to enhance that.
Speaking of modeling the clutch pivot bracket, one worry I had was whether there would be any copyright or patent problems. Fortunately I picked up this magazine yesterday and found an editorial in it that discusses that issue. Basically it says that any functional item, something that does things, cannot be copyrighted but must be patented to be protected. So, since clutch linkage brackets have been around forever I find it unlikely Ford patented them. Therefore they should be fair game.
Also, the magazine has a good review of 3D printers. So, if anyone is thinking about buying a printer this magazine would be a good resource.
Old Jan 1, 2015 | 03:15 PM
  #98
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Shapeways does wax models, for casting metal parts.
I'm sure you could have them model the sprues and risers too.
The wax figure is dipped in slip and boxed with layers of sand, then the mold is fired in a kiln to set and melt the wax out.
You can get amazing detail with the lost wax process.
Old Jan 1, 2015 | 03:17 PM
  #99
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I saw that $999 Dremel printer in HD the other day.
Still need to find time to get to Makerbot.
They are closed today
Old Jan 1, 2015 | 03:39 PM
  #100
Gary Lewis's Avatar
Gary Lewis
The Dremel came in as 12th of 26 in their tests. And there is no option for a heated build platform, so it can only be used for PLA. Plus there is no fine-tuning of things like print temps and several other parameters that make the results better. And, it has a smaller build volume than the higher-rated ones. But, at $999 vs the $2499 of the better-rated units it could be interesting for some things.
Old Jan 1, 2015 | 03:44 PM
  #101
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's at Home Depot, what do you expect.
I only mentioned it because I saw it on the magazine cover.
Really, I think the UV curing, and some 'filled' materials are of interest to me.
If I wanted to mess with a hot glue gun, I could find better ways than spending 3 large.
Old Jan 1, 2015 | 04:32 PM
  #102
Gary Lewis's Avatar
Gary Lewis
Proto-Pasta has announced conductive as well as stainless, iron, and carbon-fiber filled PLA. And, supposedly the next generation of home 3DP's will "use lasers, heat, or liquid to bind powders into solid materials."
Old Jan 1, 2015 | 05:09 PM
  #103
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sodium bicarbonate and cyanoacrylate make a pretty good combination.
There are CA's that UV cure, so the print head would not clog as long as it were opaque or amber.
Old Jan 1, 2015 | 05:19 PM
  #104
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm kind of surprised PayPal isn't after those guys for their logo.
Old Jan 1, 2015 | 05:53 PM
  #105
Gary Lewis's Avatar
Gary Lewis
Hadn't noticed the logo, but it is like PayPal's.
On the media, lots of things are telling me this isn't the time to buy in. But, it is a good time to get involved. I'm glad you pointed out FabLab and Shapeways. The classes at FabLab may be exactly what I need to get started, and for $220/year I can gain access to decent equipment and be able to get my head around what I really want to do. Thanks!
