engine degreaser
Old Dec 23, 2014 | 06:14 PM
sudsmcduff's Avatar
sudsmcduff
engine degreaser
just wondering if it is a good or bad idea to use this on my motor. also what needs to be covered up before spraying it on? thanks for any info
Old Dec 23, 2014 | 07:09 PM
F350-6's Avatar
F350-6
Many folks just use something like simple green and low pressure water. No matter what you use, the key is not to use high pressure water to rinse things off where it might get into anything electrical. (there's a lot of electrical stuff under the hood).
Generally speaking, when using low pressure water it's a good idea to cover the alternator and power steering reservoir. Also try to keep from directing the water at the UVCH, 42 pin connector, or any other electrical plug. If you have an open air filter, cover that too.
Otherwise, remember a warm engine tends to help the cleaner break down the grease, but a hot engine isn't something you want to squirt cold water on.
Old Dec 23, 2014 | 07:17 PM
sudsmcduff's Avatar
sudsmcduff
thanks for all that info and fast response. i will cover all that.
jgilrfr's Avatar
jgilrfr
What he said!
Old Dec 23, 2014 | 07:19 PM
greg_8507's Avatar
greg_8507
What he said. Simple Green is something i use quite a bit of to clean nearly everything. from the engine valley, to the intake and intercooler boots, or any other bolt on, such as the starter, fuel bowl ect.... I will use brake cleaner to deep clean and remove any residue afterwards for something like the fuel bowl, transmission pan, and so on.
Can you be a little more specific as to what you are using and what you are trying to accomplish?
Old Dec 23, 2014 | 08:12 PM
sudsmcduff's Avatar
sudsmcduff
Just trying to clean it up some and continue to regularly clean it. Not sure how harsh some of the spray can degreasers are
Old Dec 23, 2014 | 08:57 PM
crop harvester's Avatar
crop harvester
I compared some commercial cleaners & Simple Green performed about as good as any,what worked best was let it soak 15 minutes before rinsing & repeat as needed.starting out with warm not hot engine like mentioned would help.
Old Dec 24, 2014 | 10:44 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Did you use the Simple Green concentrate? If so, how much did you dilute it? Is the Simple Green lemon scented just as good? Nothing like a lemon scented turbo!
Old Dec 24, 2014 | 11:25 AM
crop harvester
I went 100% simple green,no experience with lemon flavor.
Old Dec 24, 2014 | 02:52 PM
greg_8507's Avatar
greg_8507
I use concentrate diluted 50%. Occasionally requires a little light scrubbing on caked on spots, but works well.
Old Dec 25, 2014 | 01:14 PM
jgilrfr's Avatar
jgilrfr
oven cleaner works good on stubborn areas and better if you can scrub with a wire brus,just be careful where you spray
Old Dec 25, 2014 | 04:08 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I use purple cleaner or Gunk and a pressure washer (3000 psi) or my Hotsy hot water pressure washer (1200 psi). I never cover any anything and I also don't dwell on electrical components and fluid caps. Never had any problems.
Old Dec 25, 2014 | 08:36 PM
F350-6's Avatar
F350-6
Originally Posted by truckeemtnfords
I use purple cleaner or Gunk and a pressure washer (3000 psi) ...... Never had any problems.
Most people that use a pressure washer don't have any problems...... until that one day that they do. The question really is, what PSI is that little rubber seal or gasket rated at? And how many times can it be subjected to high pressure water before it fails?
Old Dec 25, 2014 | 09:53 PM
truckeemtnfords
I hear you but like I said I don't concentrate on areas that can cause issues. In the Corps I was a heavy equipment mechanic and everything got a good pressure washing. Might be a bad learned habit but I have been lucky for 30+ years so far. I will keep pushing my luck and hope for the best.
johnnyfoodstamp
Jun 7, 2016 03:07 PM
n5926g
2004 - 2008 F150
Apr 24, 2011 04:30 PM
Joe28443
Aug 12, 2010 10:02 AM
86capriASC
1997 - 2003 F150
Aug 7, 2010 08:10 AM
Iceman31
May 4, 2006 04:43 AM
