Overhaul kit
Old Dec 22, 2014 | 07:40 PM
19711969's Avatar
19711969
Overhaul kit
Need help finding an overhaul kit for a 1971 f100 6 cylinder. Thanks in advance. Any help would be greatly appreciated. I don't want to buy junk but on the other hand I don't want to spend unnecessary money either.
Old Dec 22, 2014 | 08:05 PM
HIO Silver's Avatar
HIO Silver
What is your definition of "overhaul"?
Stick with name brands like Speed Pro, Melling, Federal-Mogul, Crane, Comp, Cams, SCE, Fel-Pro, etc.
You won't know what you need until the machine shop informs you of what is needed.
Old Dec 22, 2014 | 08:16 PM
19711969's Avatar
19711969
I'm going to rebuild the engine myself. I just want to be sure and buy the kit from a reputable dealer. So I'm really just looking for a web address or phone number.
Although I will be sending the head to a machine shop
Old Dec 22, 2014 | 08:23 PM
87crownvic2door's Avatar
87crownvic2door
go to rockauto.com they have a lot of stuff for older vehicles with a wide rang of suppliers
Old Dec 22, 2014 | 08:24 PM
19711969's Avatar
19711969
Thanks I'll check them out
Old Dec 22, 2014 | 08:29 PM
HIO Silver's Avatar
HIO Silver
Overhaul can mean a re-ring, hone, bearings, and gaskets. Some refer to that as a rebuild.
A rebuild can also entail an oil pump, cam, pistons, valve springs, keepers, valves, etc. How deep into it do you intend to go?
Machine shops tend to get good prices on branded products. Ask them what parts they recommend. You might get a good surprise.
Here are some resources:
Ford Six Performance Home/Index
Classic Inlines Performance Parts - Home
Old Dec 22, 2014 | 08:32 PM
19711969's Avatar
19711969
Will do. Thanks for the advice. Much needed. Also thanks for the web sites.
Old Dec 22, 2014 | 09:07 PM
willowbilly3's Avatar
willowbilly3
You can use stock bore low compression 2 bbl car 390 pistons on a .050 overbore and bump the compression. IIRC it's close to 9:1. Some say you shouldn't bore one over .040 so a sonic test would be prudent.
Anyone running a 300 should spend some time on Fordsix.
Old Dec 23, 2014 | 03:09 PM
JEFFFAFA's Avatar
JEFFFAFA
Have you checked the cylinders already? Prolly need a bore job of ?? oversize. Have them Vat the block also.
Old Dec 23, 2014 | 06:19 PM
19711969's Avatar
19711969
Thanks for the input. And no I haven't pulled the motor yet.it locked up on my son. I think it dropped a piston. I'm just doing the research right now on the cost. But I did have in mind to increase the power when I do go into it.
Old Dec 23, 2014 | 06:42 PM
HIO Silver's Avatar
HIO Silver
Once ya figure out the cost then factor in another 20 percent for those "intangibles".
Old Dec 23, 2014 | 07:16 PM
19711969's Avatar
19711969
[QUOTE=HIO Silver;14931950]Once ya figure out the cost then factor in another 20 percent for those "intangibles". [/QUOTE
Old Dec 23, 2014 | 07:20 PM
19711969's Avatar
19711969
Depressing!!!
Old Dec 24, 2014 | 01:23 AM
slpcth's Avatar
slpcth
To do a proper rebuild you will have to send in the block and connecting rods/pistons also. The block will need the cylinders honed at a minimum, possibly bored oversize. Also, cam bearings and core plugs replaced, hot tanking and the mains aligned bored if there is any crankshaft damage. The connecting rods should be reconditioned and pistons replaced if the block is bored oversize. The crankshaft should be polished or ground undersize depending on condition. All covers (valve cover, oil pan, timing cover, etc.) should be dropped off and hot tanked for easier cleaning.
As mentioned earlier, the engine should be taken apart and brought to a machine shop for inspection before parts are ordered. A reputable machine shop can also set you up with a good overhaul kit and many times for a decent package price with the machine work. And with the machine shop supplying the parts they can custom fit the each piston to the cylinder for perfect cylinder wall to piston clearance.
Old Dec 24, 2014 | 04:11 AM
willowbilly3
I just read the part that it locked up. There's a pretty good chance that block and crank are junk. Of course he was probably driving along normal and it just happened, right? I raised 7 boys.
