No Dash Lights
Old Sep 23, 2009 | 11:24 PM
Brock_Samson's Avatar
Brock_Samson
Question No Dash Lights
@ night I have no lights in my dash?
Where should I start my search? Its not the fuse, I checked.
Headlight Switch? Dash Bulb? What is common?
Old Sep 24, 2009 | 12:12 AM
gangstakr's Avatar
gangstakr
You turned the headlight switch? turn **** see if it works. Does inside light come on by turnight light ****?
Old Sep 24, 2009 | 05:57 AM
justiz00's Avatar
justiz00
When I first bought my pickup this was the case. I pulled the switch out and found the contact area all corroded. I tried to clean it but in the end replaced the switch, then the lights worked perfectly.
Old Sep 24, 2009 | 10:40 AM
Brock_Samson
I tred turning the **** all the way, No Cab Light.
bulb for the cab looks good so its looking like I sould pull the switch and inspect.
If it is the switch, where can i get a new one?
Old Sep 24, 2009 | 02:24 PM
xstrange's Avatar
xstrange
The '67 F100 that I bought a few weeks ago also has no dash lights at night. Then I noticed that the footwell area around the pedals would get brighter and dimmer when I turned the dimmer control......I assume that means that the lamp socket assembly has come loose and is dangling back there. I haven't pulled the cluster out yet to fix it, but at least I know the circuit works!
Just something else to check. LMC Truck has all that stuff, plus there are some guys selling replacement switches on ebay.
Old Sep 24, 2009 | 05:53 PM
justiz00's Avatar
justiz00
Your local parts store should have it.
Old Sep 24, 2009 | 08:57 PM
Brock_Samson
thanks guys
AppocAlexx
Dec 27, 2016 11:38 AM
SoCalGirl
1997 - 2003 F150
Nov 10, 2015 07:57 PM
Tugly
16
Sep 10, 2013 10:35 AM
BgDg66
New Member Introductions
Oct 11, 2007 02:32 PM
TRIEDANDTRUE
Dec 21, 2005 07:33 PM
