Output shaft spins in neutral?
Last Tuesday nite I finally got the E-Street EFI to communicate with the ECU and she fired right up. The calibration procedures went fine and the idle smooth as silk.
It's a 2WD long bed with a two-piece driveshaft but the rear shaft is out (and sitting on my living room coffee table) because I still need to finalize the exhaust system. The coupling shaft is installed to prevent the tranny lube from leaking out.... Today I fired it up and noticed the output shaft spins even when the transmission (a Tremec 5-speed) is in neutral. Is this "normal"?
I did some research and found sites which discuss viscous drag since the input shaft is turning and "In neutral, the transmission acts something like a torque converter--the input gears turn the oil and the oil turns the output gears. The effect is most noticeable when the transmission is cold and the oil stiff."
I've wrenched for years and have never encountered this. What say ye? Parasitic drag or something else?
Correct, shifter is a rail system through the top and yes, the coupling shaft turns freely with the engine off and the trans in neutral.
Is this normal for any manual trans?
+1. My nv4500 spun up pretty good when I was breaking in my cam with no drive shaft in. As soon as you would touch the output shaft it would slow and stop. Completely normal.
The collective knowledge base in this here forum is amazing.
+1 my C4 did the same thing. Without any resistance from the driveline, axle, wheels, etc. there's nothing to stop the shaft from spinning, so the smallest rotational force from internal friction will spin it.
D
bauerb
10-06-2017 11:48 PM
2pazr
17
02-20-2009 11:46 AM
DJOHNSTON78
05-14-2008 11:59 PM
Ratsmoker
06-23-2002 09:35 PM
