T-4 installation question
Old Dec 20, 2014 | 03:51 PM
jgilrfr's Avatar
jgilrfr
went to put the mount plate on and the fuel line is in the way anyone elsehave this happen and how did you get around it?
Old Dec 21, 2014 | 09:09 AM
white Buffalo's Avatar
white Buffalo
Call Matt or Jake at Irate Diesel, they will know.
But I'm curious, have you considered a regulated fuel return kit? With new injectors, S366 turbo, T-500 and all the other supporting mods you have done the stock fuel lines & check valves can be quite restrictive in the higher HP setting on your setup. Plus the added benefit of eliminating the "dead-head" stock fuel rails and preventing any air to pass through the injectors.
Old Dec 21, 2014 | 09:16 AM
white Buffalo
plus, it's common for that stock passenger side fuel line to wear a groove & leak at the support bracket, so keep an eye on it.
And almost forgot, make sure you use new pedestal O-rings when mounting the T-4 plate. My O-rings were only 6 months old so I thought they would be fine when I installed the T-4 mount. Well, they leaked and I had to take the turbo out again. I think they should add them to the kit since they are needed anyway. Watch the turbo drain into the old soft plug location. My O-rings were not a very tight fit and oil would build up around there as well. A little Ford Grey Silicon did the trick for me.
Old Dec 21, 2014 | 12:24 PM
jgilrfr's Avatar
jgilrfr
thanks for replying.I added the FRX from Riffraff and also added their high flow cvd fittings.
Old Dec 21, 2014 | 06:57 PM
Bonanza35's Avatar
Bonanza35
Is that a stock fuel line? Looks like it dips more then I remember.
Old Dec 21, 2014 | 07:53 PM
timmyboy76's Avatar
timmyboy76
Soft-line it...1/8npt(m) x 1/4jic(m). Then get a 1/4jic(f) push-lok barb fitting. Do the same off the fuel bowl...
Old Dec 21, 2014 | 07:59 PM
BadDogKuzz's Avatar
BadDogKuzz
Could it be that because of the high flow cvd fitting it is causing the fuel line to stick out alittle more than with the stock fitting.I just went and looked at my fuel line since I have that side apart and it looks like it is a little closer to the valley but hard to tell from the top angle.
Old Dec 21, 2014 | 09:54 PM
jgilrfr's Avatar
jgilrfr
high flow cvd is not the prob,the line hits the plenum and isnt even close when it comes to the mount plate
Old Dec 22, 2014 | 01:25 AM
BadDogKuzz's Avatar
BadDogKuzz
Sorry that wasn't any help but at least you already know what you problem is. Guess you'll need to bend your fuel line or get a new fuel line set up. I guess that wasn't very helpful either.
Old Dec 25, 2014 | 02:48 AM
jgilrfr's Avatar
jgilrfr
A christmas gift to all who read this,A t-4 setup does not work with a stock fuel line on an early 99 7.3,it is assumed that you will be going with a regulated return from someone other than riffraff,hopefully this saves someones time because mine got wasted and i dont appreciate it,Merry Christmas John
Old Dec 26, 2014 | 10:45 AM
BadDogKuzz's Avatar
BadDogKuzz
John HoHoHo Merry Christmas to you. Thank you so much for sharing this info and I am sorry that your time was wasted. When people like yourself share the lessons they have learned we as a group appreciate that knowledge or at least I do. I have been following your build because I would love to be able to do what you are going someday. You have used the best parts on the market and have left no stone unturned all the way down to the Fluidampr. Good job !!
Going with the T-4 with a S366 is going to be a sweet set up. Having a E99 I do not plan to upgrade to a GTP38R that is not rebuildable and limited on combos. I want a T-4 since there are so many turbo combos that can be used. The S300 series has so many turbines wheels, turbine & compressor housings, compressor wheels that you can make so many combos. And from everything I have read the S366 works great with the 7.3.
So keep up the good work.
Lex2002
38
Aug 21, 2019 12:46 PM
Tlj1227
May 14, 2012 12:15 PM
locknload223
Oct 25, 2010 12:00 PM
hitekhomeless
Oct 14, 2010 10:29 AM
PaysonPSD
38
May 10, 2009 11:43 PM
