6.0L headache
Old Dec 19, 2014 | 12:02 PM
dirkdriller's Avatar
dirkdriller
6.0L headache
2006 F250 hard to start. Ok if truck sits for 5 mins it will start fine. The longer it sits the longer it takes to fire. Noticed on the scanner the oil pressure takes a while to build the longer it sits. Did air leak test and found dummy plug oring on left side leaking. Fixed that , put back together and same thing. Pulled oil cooler out and reservoir was full of oil. At my wits end on this one. Any suggestions?
Old Dec 19, 2014 | 12:51 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
There's a possibility it is leaking from the stc fitting on the pump. If it hasn't been upgraded it will need to be changed to the one piece fitting. Most do the fitting and both standpipes and dummy plugs at the same time.
Old Dec 19, 2014 | 12:53 PM
mustang_309's Avatar
mustang_309
Change both standpipes and dummy plugs and the STC fitting. They are known to fail causing the hot nostarts you are describing.
rgraby
Aug 12, 2019 01:27 PM
dbagg
Nov 21, 2012 02:38 PM
Deerslayinrenek
Apr 12, 2011 11:15 PM
devildog12210
Nov 16, 2009 01:35 PM
andt350
Jun 6, 2007 08:00 PM
