Need help decoding door jamb sticker (noob)
Some of the things I am seeing on the physical sticker don't match what I have found on the internet. My notes are in red.
It reads:
MFD. BY FORD MOTOR CO. OF CANADA
DATE: 04/87
GVWR: 6250LB / 2834KG
FRONT GAWR: 3125LB / 1417KG
P235/75R15XL
15X8.0 JJ
AT 35 PSI COLD
REAR GAWR: 3750LB / 1780KG
P235/75R15XL
15X8.0 JJ
AT 41 PSI COLD
VIN 2FTEF14N0HCA58159
TYPE: TRUCK
EXTERIOR PAINT COLORS: 1D 1G 42
1D is "smoke metallic", 1G is "light smoke metallic", and 42 is "alpine green metallic" but my truck is blue/grey 2 tone - and there is no green anywhere
WB: 133 This one is obvious - 133" wheelbase
TYPE-GVW: F142 Can't find explanation for this anywhere
BODY: LD4 Can't find explanation for this anywhere
TRANS: A Can't find this trans code anywhere
AXLE: 19 3.55 non-LS rear axle
TAPE: 3 A thread on this forum says "3" is "Ebony" and for an Explorer not F-150. Also my pin stripe is red not black?
SPRING: D7 Spring code "D" is F-Series but what is "7"
Is it because I somehow ended up with a Canadian-built truck that I'm having these issues?
TYPE-GVW: F142 = GVWR 6250
BODY: LD4 = Bodycloth bench Seat
TRANS: A = Manual - 4-speed New Process
TAPE: 3 = Copper unless it was a tutone then it would be Medium Charcoal Red Orange
SPRING: D7 Spring code "D" is F-Series but what is "7" The 7 = E7TA-5560-KA
Yes, it was repainted - but the way the seller talked it was just a respray over the orig. color scheme. Even the door jambs , bed interior, and engine bay match. I'll have to do some investigating to see what it would have originally looked like.
I've never heard of a New Process, but now that you wrote that I was able to find some info. Wikipedia only lists a Borg-Warner T18 - was this NP-435 4-speed a special order or less common transmission?
E = Class E Hydraulic Brakes - 6,001-7,000 lbs. GVWR (Gross Vehicle Weight Rating).
F14 = F150 4WD Pickup.
N = 5.0L EFI
0 = Check digit, FoMoCo use only.
H = 1987.
C = Oakville Ontario Canada Truck Assembly Plant.
A58159 = 1987 Numerical Sequence of Assembly, the trucks specific serial number.
Warner T-18 (TRANS code F) & New Process 435 (TRANS code N [1965 only] A = 1966/89) introduced in 1965 F100/350, Warner T-19 (TRANS code P) introduced in 1973 F350.
wiki-wiki is not a very good source for info.
The New Process transmissions and transfer cases from the 60's on were made by the Chrysler Corp. They were used in both Ford and Chevrolet trucks.
NumberDummy, thanks for the VIN decoding.
Beginning in 1978, the Bronco is a completely different vehicle, 3 speed no longer available.
New Process 435 introduced in 1978 Bronco's, Warner T-18 introduced in 1979 Bronco's.
The NP435 shift lever retainer cap (B8T-7220-D) has two notches, is retained to the shift tower with 2 pins.
This cap must be pressed down by hand and held down while turning it counter clockwise to remove it.
Some people are unaware, use pliers or channel locks to remove it...which tears out one or both of the notches.
Not pleasant, because now they aren't going anywhere...until the puppy is replaced.
btw:
LD4: LD = Red Cloth & Vinyl / 4 = Styleside Pickup.
COLOR: 1D = Dark Charcoal Metallic / 1G = Light Charcoal Metallic.
42 is the DSO code = Cleveland OH Ford District Sales Office, where the original selling dealer ordered the truck from.
Thanks everyone for clearing up my confusion. I think all of my missing info has been filled in.
So NumberDummy, the paint of the truck should be a light grey and dark grey two-tone scheme? That must have looked much better than the blue - especially with a red interior. Now I will know what to do if I ever need to repaint.
Do you know which (dark or light) would have been inside the stripe?
Another weird thing I noticed that seems to contradict itself, is the badge on the fender says "XLT LARIAT" but the badge on the dash says "XL F-SERIES".
Other trucks on here have constant badging between the dash and fenders.
VIN Decoder - Ford Truck Enthusiasts Forums
General Information
<dl> <dt class="grid_2 omega"> MFR model code </dt> <dd class="omega">
</dd>
<dt class="grid_2 omega"> Body type: </dt> <dd class="omega"> Long Bed </dd>
<dt class="grid_2 omega"> Pass Doors: </dt> <dd class="omega"> 2 </dd>
<dt class="grid_2 omega"> Alternative name: </dt> <dd class="omega">
</dd>
<dt class="grid_2 omega"> Alternative body: </dt> <dd class="omega"> Regular Cab Pickup - Long Bed </dd>
<dt class="grid_2 omega"> Drivetrain: </dt> <dd class="omega"> Four Wheel Drive </dd>
</dl>
Original Pricing
<dl> <dt class="grid_2 omega"> MSRP </dt> <dd class="omega"> $21,030.00 </dd>
<dt class="grid_2 omega"> Invoice </dt> <dd class="omega"> $18,301.00 </dd>
<dt class="grid_2 omega"> Destination Charge </dt> <dd class="omega"> $640.00 </dd>
</dl>
Engine & Powertrain
<dl> <dt class="grid_2 omega"> Type </dt> <dd class="omega"> 8 Cylinder Engine </dd>
<dt class="grid_2 omega"> Displacement L/CI </dt> <dd class="omega"> 7.5/460 </dd>
<dt class="grid_2 omega"> Fuel Type </dt> <dd class="omega"> Gasoline Fuel </dd>
<dt class="grid_2 omega"> Horsepower </dt> <dd class="omega"> 210.0 @ 3600 </dd>
<dt class="grid_2 omega"> Fuel Economy </dt> <dd class="omega"> 0.0 City / 0.0 Highway </dd>
<dt class="grid_2 omega"> Fuel Capacity </dt> <dd class="omega"> 18.0 gal </dd>
<dt class="grid_2 omega"> Net Torque </dt> <dd class="omega"> 325.0 @ 2800 </dd>
</dl>
Tech Specs
<dl> <dt class="grid_2 omega"> Manufactured By </dt> <dd class="grid_4 alpha omega"> Canada Ford </dd>
<dt class="grid_2 omega">Curb Weight - Front</dt><dd class="grid_4 alpha omega">2987 lbs (2987.0 min/2987.0max)</dd>
<dt class="grid_2 omega">Curb Weight - Rear</dt><dd class="grid_4 alpha omega">2114 lbs (2114.0 min/2114.0max)</dd>
<dt class="grid_2 omega">Suspension Type - Front</dt><dd class="grid_4 alpha omega">1-Stage Multi-Leaf </dd>
<dt class="grid_2 omega">Suspension Type - Rear</dt><dd class="grid_4 alpha omega">2-Stage Multi-Leaf </dd>
<dt class="grid_2 omega">Front Tire Size</dt><dd class="grid_4 alpha omega">LT235/85R16E </dd>
<dt class="grid_2 omega">Rear Tire Size</dt><dd class="grid_4 alpha omega">LT235/85R16E </dd>
<dt class="grid_2 omega">Brake ABS System</dt><dd class="grid_4 alpha omega">Rear Wheel </dd>
<dt class="grid_2 omega">Front Brake Rotor Diam x Thickness</dt><dd class="grid_4 alpha omega">12.96 x 1.79 in </dd>
<dt class="grid_2 omega">Wheelbase</dt><dd class="grid_4 alpha omega">133.0 in (133.0 min/133.0max)</dd>
</dl>
