I’m about to have to do this when I swap to V and Mod B’s with 35”ers. Thanks for the mod idea!
I found this thread trying to verify that new Vs and 35s would work out together. I'd be sick to spend $1400 on tires to find out it was going to be a bust. Still nervous, but I think it will be ok.
The springs I’m getting have a taller rear block and 2” drop shackles and his 35” tires rubbed the inner fender wells and he had to trim the front corner of the front fenders.
Look at the tech folder up top and see everyone’s measurements before and after springs.
I have a little tire rub on the front springs at full steering lock, has been like this for the past four years, I do intend to do the steering stop mod someday but for now I just back off on the steering wheel a bit to quiet things down. I wouldn't characterize the rubbing as a bust.......
