How to fix tire rubbing the leafs on 99-04 models for $8
Tires rubbing on the leafs at full lock has been driving me effin' nuts since I installed the 35's. Inspiration hit me last night though...and it works! Only cost me $8. Would've been $2, but I lost my tap.
What you'll need
So I drilled the metal extension 1.5", then tapped the threads out until it bottomed. Then simply run the bolt down flush.
Looks about like this
As far as loss of wheel travel, I lost about 1/8" of a turn...which is right about where the wheel always caught the leaf. So IMO I didn't actually lose any travel. Did a bunch of lock to lock test on flat streets and off-camber...and NO MORE RUBBING
Enjoy, and remember to be careful if you do all your own stunts like I do!
What you'll need
3/8-16 Tap
5/16" drill bit
3/8-16 bolts (x2, 1" long)
I bought this from Lowes/Home Depot. Be careful using anything smaller, they snap easily and are a major PITA to remove...don't ask
In the picture below, you can see where the metal extension on the knuckle hits the axle. That is your turn limiter to prevent the tire from eating the leafs. The entire point of this "mod" is to extend it slightly. I highlighted the turn limiter in green.5/16" drill bit
z31freakify
22
07-19-2022 06:19 PM
SRBF150
44
02-08-2019 02:45 PM
