higher ratio rear end
Old Jul 19, 2003 | 02:28 PM
J L Hart's Avatar
J L Hart
Hello everyone!
I am new to this site and want to ask a question about my 1975 Ford f150. I recently put a new engine in my truck but I want some more get up and go. Should I consider changing out the rear end with a higher ratio? The truck tops out beautifully but it just does not pull off very well.
J L Hart
Old Jul 19, 2003 | 03:33 PM
StrangeRanger's Avatar
StrangeRanger
Give us a hint. What rear end ratio do you have now? What tranny? For that matter what engine? It all makes a difference.
Old Jul 20, 2003 | 06:16 AM
J L Hart's Avatar
J L Hart
Sorry for not giving out all the necessary info. My 1975 ford truck has a 302 engine with a fmx automatic tranny and the rear end ratio is 3.25. Like I said it has more than enough pulling power and plenty of top out cruising power but it does not have get up and go from the start. Is that part of being the truck it is?
J L Hart
Old Jul 20, 2003 | 01:43 PM
StrangeRanger
a 3.25 rear end is a good compromise between performance and cruise, especially with a non-OD tranny like an FMX.
Assuming 29" tires your RPM at 65 MPH with various rear axle ratios:
2.73 2135
3.08 2410
3.27 2560
3.55 2775
3.73 2920
4.10 3215
Those are 8.8" ratios, but the 9" equivalents are close enough. A bigger gear will give you better aceleration, but don't expect much, it's a truck. You have to decide how hard you want to rev the engine at highway speeds. I'd be inclined to leave things as they are
tofargone
Dec 12, 2010 08:59 PM
fmr9
17
Jan 21, 2008 03:30 PM
hart
Jul 12, 2005 06:15 AM
ghart81
Mar 15, 2004 07:57 AM
