whats it called
Old Dec 17, 2014 | 02:55 PM
69issofine's Avatar
69issofine
whats it called
the piece of metal between the front bumper and the core support,and are they difficult to replace? my front bumper is all twisted up from previous owner trying to push someone off a tree stump he then got mad at his wife and threw a boat oar through the sliding rear window and it continued through to the front windsheild he then took the fancy tires off the truck and gave it to me if i could get it moving so i put some maypop bald eagle tires on it and drained 5 gallons of water from the cracked tank and put in 5 or six quarts of tranny fluid in it and drove it home then about a month later i changed the tranny because the clutch pack are just heavy paper and they don't like water and boy are those trannys heavy next time i will use a tranny jack sorry for the ramble but if someone could answer my original question that would be nice.
Old Dec 17, 2014 | 04:06 PM
HIO Silver's Avatar
HIO Silver
It's the stone guard, stone shield, or valance. It bolts through tabs on the core support which are secured via U-nuts clipped on the valance. At each fender, there are three bolts (sometimes fewer) by U-nuts, nuts, or a combination thereof.
Soak the bolt threads and U-nuts with a penetrant at least the day before it is planned to be removed... the areas experience lots of road spray and dirt/grit which contribute to corrosion. I snapped off a couple of them on my rig.
Socket, ratchet, extension(s), and box wrench... some rigs have a grounding strap screwed onto the leading edge of the valance with the other eyelet under the bumper bolt nuts.. typically the passenger's side.
Old Dec 18, 2014 | 02:24 PM
69issofine's Avatar
69issofine
thats what i needed to know thank. now i need to find a new one ore a good used one.
Old Dec 18, 2014 | 02:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is your truck? As original, there were TWO different types of these stone deflectors.
C7TZ-17A862-A = 1967/69 F100/350 & D0TZ-17A862-A = 1970/72 F100/350.
Ford later replaced the 1967/69 type with the 1970/72 type.
But, AFAIK, the 1967/69 type will not work on 1970/72's.
Fords & Whalers
Nov 23, 2018 06:18 PM
greentruck72
Feb 22, 2015 04:35 PM
68cabby
Aug 8, 2012 12:07 PM
jmslmartinez
Aug 28, 2010 02:03 PM
robv60
Mar 29, 2004 11:13 PM
