Removing rear bumper
Old Mar 29, 2004 | 05:20 PM
robv60's Avatar
robv60
I would like to remove the rear bumper from my '73 F-100 for painting. What is the best way to go about doing this? What bolts,etc. need to be removed?
Old Mar 29, 2004 | 08:00 PM
RichardMaerz69's Avatar
RichardMaerz69
its easier to cut the bolts of with a sidegrinder,and replace them,and you should be able to see the bolt heads or if their carage bolts on the outside of the bumper.
Old Mar 29, 2004 | 08:03 PM
highboy1975's Avatar
highboy1975
im with richard, just grind those things off with an angle grinder and buy new ones, your probably just gonna break them off anyway, theyre probably frozen.
Old Mar 29, 2004 | 08:40 PM
RichardMaerz69
if you break them of that means you don't have to grind them,but most likely your going to round the nuts of and smash your knukels doing it.
Old Mar 29, 2004 | 11:13 PM
Quadiquizm's Avatar
Quadiquizm
I'd agree - grind em. I pulled a front bumper and 3 of 4 snapped off. Bolts are cheap, fingers are hard to replace.
