Bad Vacuum Advance?
Old Dec 16, 2014 | 07:27 PM
dstraw's Avatar
dstraw
Bad Vacuum Advance?
In this video the engine is pulling 18lbs vacuum with the vacuum advance disconnected, when I connect the vacuum line to the vacuum advance and rev the engine the idle increases and vacuum jumps to around 22 until I disconnect the vacuum line and then it drops back to 18 and the idle drops to normal.
Old Dec 16, 2014 | 07:33 PM
march's Avatar
march
sounds like you are connected to ported vacuum (above the throttle plate) vice manifold vacuum. Ported vac will increase with throttle whereas manifold vac drops.
Old Dec 16, 2014 | 07:36 PM
dstraw's Avatar
dstraw
Connected to the "vacuum tree" on the back of the manifold.
Old Dec 16, 2014 | 07:49 PM
Tedster9's Avatar
Tedster9
At idle spec the "ported" or spark advance connection should have no vacuum, thus no additional engine advance and timing is only the initial or crank advance set at the distributor.
Leaving the vac advance disconnected and plugged - the hose that is - the dizzy doesn't matter - as RPM increases, the mechanical advance should come in. Stay out of the plane of the fan blades in case they let go, but if you spool up the RPM to 3000 or more you should see all of the total mechanical advance - maybe 30 or 35 BTDC.
If you repeat the same with the vacuum advance connected you'll see an additional 10 deg BTDC or so, depending how much vac advance is set up.
Crank timing + Mechanical (weights/springs) + Vacuum Advance is typically about 45 or 50 deg BTDC at highway cruise. Or it used to be, when pump gas was good stuff.
Old Dec 19, 2014 | 09:44 AM
dstraw's Avatar
dstraw
I confirmed with a vacuum gauge that at idle the "ported" or spark advance connection had no vacuum.
It idles great see (videos below)
But stalls when you put it in gear.
Old Jan 26, 2015 | 11:53 AM
dstraw's Avatar
dstraw
I finally got the truck running!!!
After all of my carb drama..it turned out to be the points...I dropped in a new set and set the point gap and it is starting and running better than ever!
78Fords
Feb 7, 2018 10:32 AM
HoustonDave
Feb 9, 2017 12:19 PM
UZI-SUICIDE
115
Aug 5, 2013 08:00 AM
daddy172005
May 29, 2009 06:15 AM
kking1977
Apr 26, 2003 04:31 AM
