Well the brakes work fine, but it needs a pretty good pedal effort on a hard stop. No power assist here. Shouldn't it be possible to "get" the front brakes to lock up though? Yeah I wondered about the M/C. It's what everybody sells as modern replacement. Could maybe rebuild original though haven't looked at it to see if it's too pitted or worn. It maybe the fronts will see some improvement, there is maybe 10 miles on them or so.
Give them a little more mileage to seat good. You should be able to lock up the fronts, I can do it on all of mine and none are power..
Off topic but the first time I let the wife drive my 66 Mustang with none power discs I explained to her the harder pedal pressure required as compared to her car. I had her do a test stop at about 35 mph to get the feel, she stomped on the brakes so hard she bent the push rod going from the pedal to the master, and she is just a little gal.....
Tedster, I know this is an older post but I just got a set of shoes for my 1961 that has the same size shoes on all 4. Did yours work out correctly? I think your right that the manufacturers are making 1 shoe and saving time and money. I got mine at NAPA and will take them back if you found an issue with equal size shoes. Strangely, the rears have different lengths and the ones that came off were "normal" with one longer and one shorter. Your experience with these same size shoes is appreciated. How did this turn out for you?
Thanks
Brett
I can't speak for the Tedster, but in my experience the equal length shoes have not been a problem. Where I have noticed braking issues is when someone gets the shoes backwards, long friction in front and short in back causes increased braking distances. I have seen where someone put both long shoes in one drum and the shorts on the other side, It had a bit of a brake pull.
