AutoEnginuity Power Balance
Old Dec 16, 2014 | 01:38 PM
MisterCMK's Avatar
MisterCMK
Has anybody successfully run a power balance test with AE?
I have yet to get one to run properly. They always show normal, even if there is a dead skip with one injector.
I sent an e-mail off to AE tech support and we will see what they say. I wonder if there is a way to turn off FICM Compensation using AE?
Old Dec 16, 2014 | 01:54 PM
jsm180's Avatar
jsm180
The only way I can see is to shut off one injector at a time but I'm not sure that would be very accurate. There is no way to shut off FICM comp. with AE.
Old Dec 16, 2014 | 02:37 PM
dannyboy950's Avatar
dannyboy950
I think at present only IDS can turn off compensation.
Old Dec 16, 2014 | 03:36 PM
MisterCMK's Avatar
MisterCMK
Nope, shutting off one injector at a time is not a power balance.
Sent from my Telegraph using IB AutoGroup
MisterCMK's Avatar
MisterCMK
No, snap on and a few others can run a working power balance.
Old Dec 16, 2014 | 04:06 PM
jsm180's Avatar
jsm180
Understood, but that is as close as you can get with AE.
Old Dec 16, 2014 | 04:20 PM
mustang_309's Avatar
mustang_309
Will it pick up an injector that is unplugged during the test?
Old Dec 16, 2014 | 04:28 PM
MisterCMK's Avatar
MisterCMK
Hmmm
I will have to give that a shot sometime.
Here is what they have to say:
Chris,
We can’t turn off the FICM Correction at this time.
As far as the Mode$06 you need to select Generic Powertrain from the bottom of the Vehicle Selection screen, then the results can be viewed.
Old Dec 16, 2014 | 04:59 PM
dannyboy950
I know the older snap-on;geneysIII;scanXL;A&E and Matco can't turn off compensation.
Can't say about snap-on in the last 5 years tho.
Old Dec 16, 2014 | 06:20 PM
Yahiko's Avatar
Yahiko
The V 7.0 Snap-On could not.
I was told when they started to be able to
and can't recall it right now. I think it was
somewhere around V 10.0 I think they are
at V 12.0 or V 13.0 now.
Sean
Old Dec 16, 2014 | 11:46 PM
chetspencer's Avatar
chetspencer
My #8 injector is unplugged. I've been trying to explain to AE that there is a column missing in the chart but the say it's not.
Injector #8 unplugged
Old Dec 16, 2014 | 11:51 PM
87crewdually's Avatar
87crewdually
Do you have a pic of it with injector 4 unplugged? I'd like to see what it shows in the middle of the firing order.
Old Dec 16, 2014 | 11:58 PM
fordf150guy's Avatar
fordf150guy
Never thought of that but makes sence...if 8's dropping out then where is it supposed to show you? Maybe they're just not motivated to fix it since we've already given them our money...although it is one of the better consumer based scan tools it's sad that one of the most useful functions really doesn't work well at all. Atleast it runs a buzz test helping to narrow down injectors that might be sticking when cold
Old Dec 17, 2014 | 12:01 AM
chetspencer
Sorry I don't maybe someone else can take a moment to pop #4 loose and take a screen shot. My truck is running on 7 cylinders (#8 is dead) so i can't unplug any others.
Old Dec 17, 2014 | 12:06 AM
chetspencer
EXACTLY!!
Does anyone know if the Ford IDS Power Balance test has 8 columns of data?
