Newb needs help - 1956 F500 what battery?
Hi from Connecticut! Firstly, even without being a member, this forum has already given me such a wealth of information that helped me decide whether or not to purchase 1956 F500. After all the preliminary checks she seems solid and a great foundation for a restoration. So for that, THANK YOU! So now that I can post a few questions I'm even more grateful.
Once she's up and running, "Ethel" (wife already named her) will be coming home in the coming weeks. But first I need a battery. I have the parts and accessories manual and shop manual for the truck and found the tray dimensions, but can't find a battery to fit. Anyone have any recommendations?
Thank you!
Calvin
Thank you!
Calvin
Hey, Calvin! Welcome to FTE.
You should be able to find what you need here:
NAPA AUTO PARTS
If not, post back with your engine size and we'll see what we can dig up.
NAPA AUTO PARTS
Thanks for the rapid response! I've had several phone calls with Napa, Advance Auto Parts and Autozone and they all say they can't search for a battery based on dimensions. So I gave them the truck year, make and model and they checked that way. Even though some came up with hits, all batteries are higher than 8" and wider than 5.5".
Engine is a 272 (I think). I can't find any information that would indicate it is a 292. I decoded the VIN (F50V6E47653) and it seems the "V" indicates it is a 272.
I'm curious to know what the owners of the same truck are using.
Probably used a group 29
Just find the largest, heaviest highest CCA battery that will physically fit and you'll be all set. A farm and fleet store would work here, bring a tape measure.
edit: Was the 56 originally a 6 volt positive ground? That would explain the sizing issues, if so. Most had been converted to 12 volts at some point.
Yup I caught that too...saw a great post from some time ago showing the differences between the models (F100/F500) through the years...I believe '53-'56. I like the 12 volt system since I can put a winch on the back to pull my Farmalls on the bed. Of course can't get a winch to work if I ain't got a battery.
While I'm thinking of it, it would be wise to buy a trickle charger, or a good battery maintainer, when buying a battery. Unless this is a daily driver, many batteries in collector cars are ruined by sitting for long periods. That way it will give good service when called upon and you can keep other equipment charged up too. And they sure are cheaper than batteries and alternators.
If you are using a winch, you probably would best be served with an AGM battery, as they will handle deep discharges.
Thanks all!
Seems I'm reading the information in the Parts and Accessories catalog possibly incorrectly. There are "battery chart" and "battery hold down" dimensions. Basically the battery chart indicates the battery is 5.5" wide by 8" high and either 12.5" or 14.5" long. Can't find a battery these days even near these dimensions. Then I scroll down to the next page and see the battery hold down dimensions. There are three listed and I don't know what this truck's battery holder is supposed to be. Two are non-adjustable 5-11/16ths by 12-5/8ths" or 14-3/8ths while the other is adjustable. Looks like I'm taking an hour's drive to measure the box myself. I probably should've done that before bothering you fine folks. I'll report back! THANK YOU!
EDIT: I think I just found my solution! http://midfifty.com/item.php?INV_ID=51
You're overthinking this. I think.
If you were to pick a modern auto start battery at random it would likely be just fine. What does the truck have for a charging system? This is just as important, is it a stock 30 amp generator, or has it been converted to alternator? Most people don't want to mess with generator regulators and/or have lots of modern accessories that a generator won't support.
Well that's admirable, but there are reasons modern trucks have alternators and disc brakes, fuel injection, electronic ignition, power steering, etc. If you want old school, you better bone up on some old school readin' material.
The Ford Truck Shop Manual for your year truck is a good start, and a 1950s vintage Chilton's or Motors general auto repair manual.
