Cannot get gas in tank
Old Dec 14, 2014 | 10:23 AM
Crazykwaaks's Avatar
Crazykwaaks
Hello All, I have read many post and tried so many things I don't kow where to begin to start. I cannot get gas to go into the tank on my 1986 F 150. I bought thetruck from a one owner friend. He put in a new gas tank several years ago and did not mention having this problem. The truck was sitting for a few years and only driven a few times. I have removed the filler tube and the inner small vent tube is there and not kinked. I have repositioned the filler tube many different times a little at a time, no help.
I am also having a problem that just started. The engine will start and idle with no problem. While driving the engine will die after a few miles or not even a mile. It sometimeswill start right back up or let it sit for a min and it will start but slow to start like the battery is week. I can give more details on any questions anyone has, and any info anyone can give is greatly appreciated. Thanks
Old Dec 14, 2014 | 04:28 PM
Franklin2's Avatar
Franklin2
What engine? The little hose inside the big hose IS being held in position by the metal clip inside correct?
Can you fill it at about half-speed at the pump? Even after fixing my little hose and clipping it back in place, I still could not fill at full speed. They say they re-designed the filler hoses on the later trucks, maybe you could go junk yarding and find one of those.
Old Dec 14, 2014 | 05:52 PM
86fn150's Avatar
86fn150
best mod for a pre 87.the only thing really to modify is getting rid of the little holder in the tank neck ( for the inner corrigated tube so the new style will fit in).if you get a newer style-make sure the inner tube doesn't move/separate from the unit as there is a hidden clip way up in the metal tube that holds it)
john165
Jul 30, 2014 04:01 PM
jackfast1
20
Dec 6, 2003 03:44 PM
oldcoupe42
Oct 29, 2003 03:36 PM
Panzermitch
Sep 7, 2003 12:15 AM
cheb712
1983 - 2012 Ranger & B-Series
Jan 15, 2003 03:25 PM
