motor id
I was wondering if anyone had an idea on how to tell what era an engine comes from. I have a 1971 f100 that came with a 240 six it now has a 302 v8. the problem I have is when I ask for parts the folks ask for the year model. and now I have been told that in 1976 is when they made changes to the motor so how can I tell if it is pre 76 or post 76? any points would be much appreciated.
thanks
sam
Drives me up the wall when counter people quiz me on year and engine ect for stuff I know is completely irrelevant. I know its the way it works, but most of the time for my needs it just makes me shake my head.
As I understand it, the rebirth of the V8 into Mustang IIs began in the initial year with a 255 Windsor. This motor had a smaller bore than the 289/302. I think the 5.0 was a re-design for the new Fox body Mustangs (and all the other cars and light trucks that would use a small V8)
I am trying to find a exhaust manifold left hand side dual exhaust. looks like the major difference is where the exhaust connects to the pipe. the dual has an angle towards the rear and the single comes straight down more or less. any other difference I should look for?
The major changes to the 302/5.0L engine came in 1981.
Prior to '81, there'll be a threaded hole at the left, rear corner of the block for a mechanical clutch linkage pivot to screw into, for a manual transmission. From '81-2001, there will not be a threaded hole there.
In '81, the front and rear main seals went to a one piece design from the older two piece design.
The '81-2001 front cover will have a crank seal that installs from the front of the engine. '80 and earlier will require removal of the front cover to replace the seal. --there are various different front cover designs. Some have a hole for the dipstick, some don't. Some have a hole for a mechanical fuel pump, some don't. Some have a provision for mounting a crank trigger sensor (Explorer with EDIS-8 Distributorless ignition system).
'81-2001 will have a 50 oz reciprocating assembly imbalance. '80 and earlier will have 28 oz imbalance.
First H.O. (High Output) 5.0L engine was put in the '85 Mustangs. This was the first use of a 5.0L roller cam engine and also the last year for a carbureted 5.0L (302) engine.
All 302s and non-H.O. 5.0L engines have a 1-5-4-2-6-3-7-8 firing order. The H.O. 5.0L engines have the same (improved) firing order as the 351W/5.8L engines; 1-3-7-2-6-5-4-8.
5.0L engines that came with a serpentine belt have reverse direction (flow) water pumps.
'68/'69 water pump outlet exits to the right. '70-2001 exits to the left.
(At least on the cars) Harmonic balancer and pulley will have 3 bolt holes on '68/'69 model 302s. '70-95 cars will have 4 bolt harmonic balancer/pulley.
Explorer 5.0L engines, without a distributor, will have 3 bolt harmonic balancers and the serpentine pulley is cast integral to the balancer.
On my inline six, the number is C6AE-6015-D, and then two inches over you can see an 8L7.
The first letter is the decade in which the casting was designed.
B = 1950s
C = 1960s
D = 1970s
E = 1980s
F = 1990s
The number is the year in which the casting was designed.
With mine being C6, the casting was designed in 1966. That does not, however, mean that the block was cast in 1966. That's what the 8L7 date stamp is for.
The first number is the year of the decade in which the block was cast, and being a C6 block we can assume it was in the 1960s. Therefore, an 8 would indicate 1968.
The letter is the month in which it was cast, from A-M, omitting the letter I. Each letter indicates the month in numerical order. The letter L would therefore represent November.
The last number is the day of the month in which the block was cast.
From this, we can conclude that my block was cast on November 7, 1968.
I'd say find any small block (windsor) exhaust manifold from a pickup truck.
thanks again
sam
Decent 302 head casting numbers are: D0OE-B, D1TZ-A, D5OE-GA, D5OE-GA and D5OE-A3B. The D5OE heads were the first to be fitted for Thermactor through the ends of the casting instead of over each exhaust port. This eliminated the external air manifold. The hole can simply be plugged if not running the emissions plumbing and air pump.
'77 is when things really started going down hill for the 302 heads. '77-'84 heads increased to 69cc combustion chambers, which lowered the compression, and performance, significantly.
It's pretty easy to spot the non-desirable 302 (and 351W) stock iron heads just by looking at the spark plugs. If the heads have 18mm plugs (requires a 13/16" socket to remove/install plugs), they are the better heads. If the spark plugs are 14mm (5/8" socket), they are the less desirable version.
Non-desirable 302 head castings are: D7OE-DA and D8OE-AB.
The best flowing factory iron heads come from the 5.0L Explorers. Prior to 1997-1/2, the heads used were the GT40 (3 bar) heads from the 1993 Cobra Mustangs --minus the performance valve springs and factory roller rockers that were on the '93 Cobras.
From 1997-1/2 - 2001, there was another improvement in the 5.0L iron heads. This version was the GT40P (4 bar) heads. These heads outflow and out perform both the old 289 HiPo heads and the early 351W heads.
btw: Mustang II: 1974/78 - available with 2.3L OHC 4; 2.8L V6 & 302 (1975/78).
Fox body Mustang introduced in 1979, 255 (4.2L) introduced in 1980.
