Not quite broke down in TX/AZ - map sensor???
Old 12-17-2014, 01:44 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,899 Likes on 1,145 Posts
Yeah, it runs fine with map unplugged - just sets CEL.
Thanks Pop!!!!!!
  #32
Old 12-18-2014, 10:42 AM
BadDogKuzz's Avatar
BadDogKuzz
BadDogKuzz is offline
Thanks Pop!!!!!!
Just wondering did you ever find the problem, bad pin somewhere or a bad wire ??
  #33
Old 12-18-2014, 10:31 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
Jason if you need a new coolant sensor grab the cheaper of the 2 at Oreilly. One is for reporting to pcm, thats the wrong one.
mine just quite working after I pulled it to replace therm gasket. Got to drain radiator 3 freaking times.
It may have even beenautozone
  #34
Old 12-18-2014, 10:40 PM
petrokiller
  #35
Old 12-18-2014, 11:56 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
I was out to see Jason yesterday, and we determined that he had, indeed, a bad coolant temp sensor.
Comparing the sensor's resistance values at ambient, they were off by an order of magnitude.
One read about 1.8K ohms, the new one read 18K ohms.
Using a Zippo on the new sensor, and watching the needle start upward, confirmed that the new one needed to be installed.
He drained the coolant, used a wrench, re-installed the coolant, and WAA-LAA! Good to go!
Sometimes you just get lucky!
Pop
  #36
Old 12-19-2014, 08:21 AM
SkySkiJason
Pop
I think the other coolant temp sensors I tried were the wrong ones like Brad said...
It was great to meet you Marv and thanks for the help!! I don't get out that way very often so I haven't gotten to meet many left coasters.
Unfortunately, the new MAP did not solve the original problem. The codes all go away with MAP plugged in, but truck has no power/no boost. Unplugged it runs great, but sets SES and the following codes:
P0237 - Turbo Boost Sensor A Circuit Low Input
P1247 - Turbo Boost Pressure Low
P1248 - Turbo Boost Pressure Not Detected
And not related? It is hooked up though...
P0541 - Manf Intake Air Heater Circuit Low
Unfortunately, I had to leave and now I'm paying a shop in LA $95/hr to diagnose this. Anything I can give them to help resolve this will help save me $$$...
  #37
Old 12-19-2014, 08:34 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
that blows, jay. Probably have, but you inspect the map hose?
  #38
Old 12-19-2014, 08:57 AM
BadDogKuzz's Avatar
BadDogKuzz
Well like Tim said check the hose and see if you can blow thru it. Also if you could pin test (ohms) the 3 MAP sensor wires back to the pcm plug you could rule out wiring. If the wires are good I would be looking at trying a different PCM to rule out something wrong with pcm.
  #39
Old 12-20-2014, 03:10 PM
SkySkiJason
Yep, pin out tests good... Sending another PCM Monday.
  #40
Old 12-20-2014, 04:46 PM
BadDogKuzz's Avatar
BadDogKuzz
Changing out a pcm is alot easier than finding a bad wire. But sorry it is going to cost you a pcm. If it was a bad wire I myself wouldn't even go looking for it and just run a new wire to the pcm.
So are you home or on your way home?
  #41
Old 12-21-2014, 10:33 AM
SkySkiJason
I flew home Thursday.
I have a pile of PCM's at the shop, just hoping I have one for that truck... I have another '02 I recently built that I can try the 'new' PCM in - so I can at least try to verify it works before I ship it.
  #42
Old 12-21-2014, 10:42 AM
BadDogKuzz's Avatar
BadDogKuzz
Good idea on the pcm. I don't know about you I always enjoy a nice long road trip but I am always happiest when I get back home to my family and my bed.
  #43
Old 01-09-2015, 09:04 AM
SkySkiJason
Looks like the PCM I sent out fixed the MAP sensor problem. Crazy it failed like that...
Thanks again for all the help and moral support y'all!!
  #44
Old 01-09-2015, 09:40 AM
SpringerPop
That's kind of an easy fix for what was a hair-pulling problem!
It's a VERY-lucky girl getting that truck as her first "car". She'll be able to go anywhere in style and luxury, take a few of her friends with her, and tow a trailer full of their horses as well. Her dad's a VERY-smart guy!
It was great getting to meet you when you were out here, Jason. Let us know when you again get out this way, and we'll get together again!
All the best to you.
Pop
presbow
17
04-30-2018 07:53 AM
brichert
05-26-2017 06:46 AM
RideDiesel88
01-28-2015 07:30 PM
20powerstroke02
11-17-2014 07:21 AM
TNT in Round Rock
01-24-2012 03:58 PM
Quick Reply: Not quite broke down in TX/AZ - map sensor???
