power steering leak
Old Dec 12, 2014 | 06:59 PM
th3jared's Avatar
th3jared
power steering leak
I finally found the like that was leaking on my 06 f550.
I saw a drop come of the fitting for the power steering up right beside the brake fluid fill container. I've got 2 questions:
1: I can't seem to find this part to order it, can someone please point me in the right direction.
2: I typically have a shop do the work on this truck but I think I might save money and do it myself.it looks easy, is it as easy as it looks to replaced this line. (Will the brake fluid container need removed then re attached after ward's and brakes bled)
Old Dec 12, 2014 | 07:22 PM
MisterCMK's Avatar
MisterCMK
Did you try tightening the fitting? I had a leak back there and it just needed to be tightened up.
Sent from my Telegraph using IB AutoGroup
Old Dec 12, 2014 | 07:38 PM
th3jared's Avatar
th3jared
Haha no. I'll try it in the morning when I have day light. You just used a regular wrench? Its pretty tight squeeze back there
Old Dec 12, 2014 | 10:14 PM
MisterCMK's Avatar
MisterCMK
Yup. It looks tight but isn't bad to get to
Old Dec 13, 2014 | 03:24 AM
87crewdually's Avatar
87crewdually
Mine was leaking there once. I disassembled and replaced the O-ring. That was over 2 years ago.
Old Dec 21, 2014 | 07:08 AM
th3jared's Avatar
th3jared
Just wanted to update the outcome of this.
Did take a better look at this fitting and it was loose (hand tight) but I had already got the o-ring replacement so I went ahead and replaced it. Done this yesterday abd no leak today so I'm ruling this a successful fix.
THANK YOU guys for your quick and to the point help!
Critterhunter
1983 - 2012 Ranger & B-Series
Jul 24, 2020 10:25 AM
phantomphixer
Jul 17, 2014 12:20 AM
cardiacjohn
Sep 14, 2013 12:55 PM
Stealth94rttt
Feb 16, 2013 10:29 AM
John7894
Aug 16, 2012 07:55 PM
