Code 0603 need help
Old Dec 11, 2014 | 06:35 PM
ADMSWELDING's Avatar
ADMSWELDING
Code 0603 need help
Scanned my 04 6.0 yesterday had codes 0299 tc underboost and 0603 internal control module.The turbo code I have had for awhile and truck was blowing blue smoke when cold.Replaced turbo today but havnt had chance to rescan or clear codes.Test drove truck briefly had no smoke.Wondering what the code is about.Diesel mechanic at dealer is friend of mine said usually caused by dead batterys.Those are fairly new maybe 2 years old.Truck recently had new fuel pump,ficm and front fuel tank and number3 injector replaced.Just a little info.Any held is appreciated thanks in advance.
Old Dec 11, 2014 | 06:42 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Disconnected batteries can cause the P0603
DTC P0603
How Set C - Continuous Operation
Condition DescriptionPowertrain Control Module Keep Alive Memory (KAM) Error
Fault Trigger/Comments .No historical faults output during self test
Probable Causes Disconnected/Discharged Battery, Open PCM pin, faulty PCM.
Old Dec 11, 2014 | 06:45 PM
ADMSWELDING
I disconnected them when I did the ficm.But I cleared the codes yesterday and it came back.Also have low glow plug circuit 8 forgot to mention that also
Old Dec 11, 2014 | 07:05 PM
ADMSWELDING
Also truck seems still to still be a little sluggish after I did the turbo today.I located my pcm in the tech folder will check those connectors tomorrow.
Old Dec 11, 2014 | 08:27 PM
78fordman's Avatar
78fordman
Do a vgt relearn.
Old Dec 13, 2014 | 02:06 PM
ADMSWELDING
not related to the code but truck is better
Found the problem the pigtail on the fuel pump on frame rail.Dont know if it corrosion or broken wire.Wasnt providing full power to pump and was losing fuel pressure.Truck stalled this morning and wouldn't re fire.Opened top fuel bowl no fuel pushing to it.after unplugging and repluging in pump few times turned key and it started pushing fuel again.Went to dealer got new pigtail its the 2 into 1 lm refering to and all seems good.The codes are gone and truck is running strong.Thanks guys for the help you provided.
Old Dec 13, 2014 | 09:20 PM
Yahiko's Avatar
Yahiko
Cool and thank you for posting back on the fix.
Sean
jimjokjv
Aug 2, 2017 06:59 PM
hifiman
Sep 12, 2010 09:28 AM
dyhrdford
General Automotive Discussion
Aug 17, 2009 06:43 AM
ALF1999
Oct 29, 2005 06:13 PM
beaboarder
Feb 11, 2004 06:08 PM
