My truck is a 2012, has the step, no bracket, and no apparent place it should be mounted, so my guess is a running change. This may indicate that they had issues and put these on to fix them.
So I looked at my bracket yesterday and don't see what function it serves.
When I first saw it several my assumption was it was something to help keep the tailgate in place in the event of an accident.
Have step, have bracket.
Leaving it on. My take is Ford didn't spend the money to add that item if it wasn't necessary.
I use the step.
I have the step and haven't removed the bracket (yet). I did remove the stripper pole though and put a flat tailgate liner on as the pole was always in the way sliding stuff into the truck. I rarely use the step anyway. I'm only 58, I can still climb in without it.
Maybe next year the SD will come with the F-150 flat tailgate with pole and step.
I'm 58 too, and can climb it as well. But I still like the feature.
What I don't like about it is the pole sticking up above the tailgate surface and the step will unlatch/flip when I close the tailgate if I push on the center of the gate. Took care of the pole and I try to push the tailgate up from either side. It's handy because it's there, don't think I'd pay for it on a new truck though, mine was a used purchase.
hm..I don't see any of those problems.. the bed rails installed by the PO give me way more trouble than the pole ever did.
my knees thank me every time for the step and pole. Used it yesterday to put the xmas tree into the bed and take it out.
Christmas trees. We cut ours down a couple weeks ago.
I special ordered my truck and did not order the tail step. Reason? I hated the pole and the plastic bumpy crap on the tailgate. Always tore it up trying to slide stuff in and out of the truck.
Also, the top pieces of plastic on the tailgate always got busted up and loose (the things on either side of the pull out step). I really like my new plain tailgate door but I do miss the step. Takes more effort to get in and out of the bed, but I'm good with it.
For all the reasons the pole is hated I agree. It's a PITA to slide anything of weight over it. I've owned Ford trucks since 1976 but at my age of 64 it's a very nice option to have.
they should put a geritol bottle holder by the handle and step in the tailgate. maybe they could also put a holder for some oversized sunglass or blue blocker sunglasses.
