need help
Old Dec 9, 2014 | 09:04 PM
arrowheadfred's Avatar
arrowheadfred
need help
Hey guys been along time. I had trouble with my brakes so I thought it was the booster. The brakes stop ok but the pedal won't return all the way up. I replaced the whole disk\disk power brake system and it still doing the same thing. OK some good news I GOT A BRAND NEW 2014 MODEL GRANDSON. That makes two.
Old Dec 9, 2014 | 10:14 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I don't know about your brakes, but someone else had the same trouble not that long ago, so stay tuned someone should chime in. OK, now on to the good news "Rite on" it truly warms my heart for reasons that you already know, blessings my friend.
Old Dec 9, 2014 | 10:19 PM
jmadsen's Avatar
jmadsen
Hi Fred. I was thinking about you the other day.
You really need this ebay item # 331404406385
couldnt get the link to work.
And sorry but im no help with your brakes.
Besides brakes are for people who want to go slow anyway.
And congratulations on the new addition to the family. Does this mean your gonna have to buy another f1?
Old Dec 10, 2014 | 12:08 AM
arrowheadfred
ot-2014
Jace Kent. Ford man like his papaw
Old Dec 10, 2014 | 09:48 AM
Rimrock F1's Avatar
Rimrock F1
You say booster so I assume power brakes? If that is the case in all the types I have seen the pedal does not attach to the booster, it only pushes on a plunger inside the booster. A spring returns this type of pedal so the only thing I can think of that would cause it not to return is binding in one of the pivots or linkages.
Old Dec 11, 2014 | 12:29 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Welcome back Dale. I can't help with the brake question, but congratulations on the new grandson!
Old Jan 27, 2026 | 07:00 PM
Daniel Yosef's Avatar
Daniel Yosef
Help with drum kit
Hey guys. Thankfully, after re doing all the brake lines and hoses, I start the drum work. I got new shoes and kit for the rear and I just can’t figure out what’s wrong here. Doing everything with a video and still, one shoe just end up way high and I cannot close the drum right.
please help- see att
achment
Old Jan 27, 2026 | 07:39 PM
lshort's Avatar
lshort
What are the wheel cylinders like? Make sure the pistons are free in the bores and you can push the little push rods back in, also completely back off the parking brake cable adjustment and make sure that the cable is free and not stuck and the parking brake lever is all the way in the disengaged position.
Also your residual pressure check valve may be causing you problems, try opening the bleeder valve and see if that helps.
Also make sure that the cross piece for the parking brake is seated properly, that is a trick piece to get in correctly
Old Jan 28, 2026 | 05:23 AM
Daniel Yosef
im starting to suspect my assembly is not right. I think the shoes might be on the opposite side of where they need to be, same goes for the hardware.
at least from pics online and as a comparison to the other rear wheel (needs to mirror it correct? )
Old Jan 28, 2026 | 10:49 AM
lshort's Avatar
lshort
this is what i go by
Old Jan 28, 2026 | 01:05 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The smaller brake shoe pad is the PRIMARY shoe and always faces the front of the vehicle.
Old Jan 28, 2026 | 02:47 PM
oscar1955's Avatar
oscar1955
The shoes and hardware look correctly installed. Looking at the upward angle of the rear wheel cylinder rod to brake shoe it appears the wheel cylinder piston is stuck. Brake fluid will draw moisture and if the truck has been sitting for long time it is a good indication the pistons are stuck. Lift the rubber boot and see if it’s corroded.
Dennis Bloxham
Flathead V8 & Flathead 6
Oct 27, 2013 10:27 AM
devino246
Nov 18, 2011 07:48 PM
Pappys53
Sep 26, 2008 09:45 PM
MadFF
Sep 3, 2008 10:17 AM
idealtrucks
Dec 23, 2003 09:37 AM
