Sponsored by: Real Truck
Battery drain
Old Dec 9, 2014 | 03:32 AM
bigcountry1009's Avatar
bigcountry1009
Battery drain
I'm waiting on Christmas shopping to be over to replace the ICP and IPR on my '01 F250. In the mean time I have been going out every few days to crank it and let it run up to temp. Now, however, my batteries have slowly been getting drained over the past month, to where it finally wouldn't crank yesterday. So I'm wondering if I now have a drain somewhere, or is running it at idle for about 20 mins just not sufficient.
Old Dec 9, 2014 | 04:33 AM
buba 11's Avatar
buba 11
Do not know what you got but in my truck I found that one battery was NG and was draining the good one. Not sure if this helps__replaced the bad one and everything is OK now. funny but the good one had acid on top corroding away the battery holder, the bad one had nothing, dry on top. now they are both dry
Old Dec 9, 2014 | 05:36 PM
bigcountry1009
The batteries are both new. Put them in last month. And I didn't seem to have a problem until it had to be parked.
Old Dec 9, 2014 | 05:45 PM
Tedster9's Avatar
Tedster9
Keep it on a charger till you get it sorted out. About 20 amps is a nice slow charge. Mismatched cells (or battery) draw mismatched current and will constantly gas. That's why the corrosion.
Old Dec 9, 2014 | 06:01 PM
Just Strokin's Avatar
Just Strokin
Generally at idle, on any vehicle with alternator, is not adequate to recharge/maintain a battery. The truck takes a lot of amps each time you start it due to glow plugs and then turning the starter to crank over the engine which has 16 to upwards of 20 to 1 compression ratio. Best to get a trickle charger to maintain the batteries till you can do the repairs.
I use to keep a schmidt 1.5 amp trickle charger on my 96 7.3L when not in use.
If you had an AIC (auxiliary idle controller) you could raise the idle to say 1300 rpm to possibly charge the batteries.
Old Dec 10, 2014 | 03:24 AM
bigcountry1009
Thanks guys. I was looking at a trickle charger/maintainer. I also searched and found out how to test for a parasitic drain due to a switch being left on or something. I did change the ignition lock right before this happened and the "key in ignition" chime never goes off. Not sure if that'd turn something on or not.
Old Dec 10, 2014 | 08:10 AM
BoKnowsDiesel's Avatar
BoKnowsDiesel
Former Vendor
Once you get the time, diagnosing a drain isn't too hard. Just time consuming. You want to drive the truck for a bit to make sure all the modules are awake. Shut the truck off and let it sit for about an hour (giving the modules time to fall asleep again). This is the tricky part, you need to disconnect the negative battery cable, but keep continuity from the post through the cable using the leads on a DMM. Failure to keep continuity at all times can wake a module up. If a module (like a GEM module) is awake, it will skew your readings. Set the DMM to DC amps, anything over 50 mA is too much. Keep the DMM hooked up and start pulling fuses, amps will drop when you pull the fuse on the drawing circuit. Now that you have narrowed it down to a single circuit, start at the furthest away part of the circuit. Start unplugging components, working your way up the circuit. When you unplug a component and the draw drops on the DMM, you have found the problem.
Old Dec 11, 2014 | 04:31 PM
speakerfritz's Avatar
speakerfritz
Idle wont cut it.
battery age is a factor on how well they recharge
cold cold weather is another factor
Old Dec 12, 2014 | 08:18 AM
DavidB's Avatar
DavidB
Here is a better way to do battery drain testing:
Old Dec 12, 2014 | 08:36 AM
BoKnowsDiesel
Former Vendor
Using fuse voltage drop is easier, I still like to use an ammeter to confirm draw. I have the charts for all the different types of fuses, and what the voltage drop will be if any one is interested.
Old Dec 12, 2014 | 02:46 PM
rcsuhta's Avatar
rcsuhta
Hey Bo I would love to have a copy of those fuse charts.
rcsuhta@gmail.com
Thanks
Old Dec 15, 2014 | 10:41 AM
BoKnowsDiesel
Former Vendor
Sure thing, I will try to get that out to ya sometime tomorrow
bluegoose95401
Aug 5, 2014 02:59 PM
abeagle
39
Apr 6, 2014 04:22 PM
pauldfixr
Nov 17, 2009 10:35 PM
Copedawg
15
Jul 3, 2009 06:48 AM
Railmonkey
2004 - 2008 F150
15
Mar 13, 2006 10:18 AM
