Preventing battery drains
Old Dec 8, 2014 | 01:20 PM
bigtexan99's Avatar
bigtexan99
I've got a slow drain that I've been unable to isolate.
Going to not use the truck for a few weeks, which battery cables should I disconnect?
a) both negative cables, leaving positive connected
b) both positive cables, leaving negative connected
c) all 4 cables, neg and pos.
d) other?
Old Dec 8, 2014 | 02:30 PM
Pikachu's Avatar
Pikachu
You can drop just the ground cables off the posts and it'll be fine.
Old Dec 8, 2014 | 08:38 PM
bkuuz1's Avatar
bkuuz1
I had a battery drain (batts would only last a week at the most) that turned out to be the alternator was shorting. I found it by accident. I just happened to have touched the alternator after the truck sat over night when it was really cold out and the alternator was warm. Replaced the alternator and and haven't had anymore issues.
Insane451
Apr 3, 2014 11:05 AM
turbogus
Electrical Systems/Wiring
Aug 29, 2013 08:25 AM
OlpA77
Bronco II
Sep 9, 2007 08:03 PM
Duran7
May 20, 2003 01:46 AM
tdsimmo
Feb 22, 2003 07:24 PM
