I am guessing the seats didn't come that high off of the floor in the Taurus. How high did you need to raise them?
I built my own mounts I think it was about 2". Based on the following: the floor was raised (channeled)3" and then setting 2x4 under the original seat mounts I set the seats so that my left arm would be level in the door window opening.
Wow... She is turning out sweet... You do great work! How did you finish the tonneau cover? How about a close up pic of your gauge cluster...
Thanks for the comment. The Tonneau is painted the same color as the pickup and will be the last part re-installed. The gauge cluster is the VHX series from Dakota Digital.
_______________________________________________
48 Ford F1 - Darkside
46 Ford Tudor - Street Rod
