Fordomatic - 5 questions
Old Dec 8, 2014 | 08:12 AM
1954_NJ_F100's Avatar
1954_NJ_F100
I am switching out a manual steering column w/ a Fordomatic and using a C-4 trans. Can anyone help or advise on any of these:
1. Did anyone ever position or modify a neutral safety switch so the truck will only start in Park?
2. I have both Fordowmatic and Cuiseomatic shift indicators...anyone have success using a Cruisomatic indicator w/ a C-4?
3. Linkage ideas or suggestions?
4. Is it dimensionally possible for the column come out with the shaft in-place? Or do I have to drop the steering box?
5. Anyone know what wires go to the four terminals or have a wiring diagram for the neutral saftey switch?
Thanks for any help or suggestions!
Old Dec 8, 2014 | 08:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NSS (Neutral Safety Switch) allows the vehicle to be started in Park or Neutral, it is steering column mounted.
Which Cruise-O-Matic shift indicator dial do you have? There are at least 5 different types from 1957 thru 1979.
When introduced, both the C4 & C6 were known as Cruise-O-Matics. FX, FMX & MX are also Cruise-O's.
Old Dec 8, 2014 | 11:29 AM
Rimrock F1's Avatar
Rimrock F1
I have a 56 Fairlane that I changed from FordOMatic to C4. I kept the column mounted neutral switch, it will start in park or neutral. I used the stock column indicator, reads great except reads 1st or low when you are actually in 2nd. Used the stock shift linkage with slight modification, works great except you can't shift into 1st or low only 2nd. All other shift positions are find P,R,N,D, 2nd. Used the stock crossmember with some modification.
I know this is a car and not truck but maybe some help to you.
Old Dec 8, 2014 | 11:11 PM
49 Merc P/U's Avatar
49 Merc P/U
You would want to have the engine start in neutral or park other wise if your engine stalled in traffic you would have to stop and put it in park before you could start it . ie no rolling start. That could be very dangerous in traffic or on the freeway.
Bruce
Old Dec 26, 2014 | 08:06 PM
1954_NJ_F100
Thanks everyone.
Old Dec 27, 2014 | 07:39 AM
38 coupe's Avatar
38 coupe
In the 1953 Fords the neutral safety switch only allowed starting in neutral. The engine would not start in park. This is a column mounted switch. I don't know when Ford initially allowing staring in Park.
iron1951
Feb 18, 2011 06:39 PM
nosagroy
Apr 3, 2009 08:25 PM
53Merc
22
Aug 1, 2005 08:33 AM
Don Beale
May 7, 2001 07:57 PM
John Boggs
1983 - 2012 Ranger & B-Series
Dec 7, 1999 08:34 PM
