please help won't start
Old Dec 8, 2014 | 07:00 AM
nick3680's Avatar
nick3680
2000 ford excursion limited v10 removed factory radio and put aftermarket stereo now wont start just clicking
Old Dec 8, 2014 | 07:18 AM
projectSHO89's Avatar
projectSHO89
Did you leave the doors open while working on it and run the battery down?
Old Dec 8, 2014 | 07:21 AM
nick3680's Avatar
nick3680
Yes I did but it also has factory anti theft and aftermarket alarm and remote start in forgot to mention
Old Dec 8, 2014 | 08:24 AM
ghglenn's Avatar
ghglenn
Battery is dead? Jump start it.
Old Dec 8, 2014 | 02:26 PM
projectSHO89
Step 1. Make sure the battery is fully charged.
Step 2. If you think you can bypass Step 1, think again. Return to Step 1.
Old Dec 9, 2014 | 12:40 AM
Immortal_Ben's Avatar
Immortal_Ben
Battery fo sho.
Old Dec 9, 2014 | 06:39 AM
sammie0126's Avatar
sammie0126
Battery is dead, been there done that, jump it -then consider if you need a new battery. Not sure how long you had the doors open but if it was not an obscene amount of time you need to consider the strength of your battery. How old is it?
Old Dec 9, 2014 | 08:18 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
When they installed the remote start/alarm on my '05, they neglected to put a trickle charger on the battery and ran my batteries almost dead. It was just enough to start the truck and it took the whole drive home to recharge.
Pull the battery, check the date and make sure it's not too old, make sure it's topped off with distilled water if necessary, slow charge at autozone or oreilly if you don't have a charger and you'll be good to go.
graypatrick093
May 19, 2015 05:41 AM
Bdanger231
Aug 6, 2012 11:58 PM
superman724
Aug 31, 2009 01:20 PM
esco24
Nov 27, 2007 10:41 AM
