Help troubleshooting
Old Jan 16, 2015 | 07:56 PM
subford's Avatar
subford
Originally Posted by Stevaroo01
Is it possible for these switches to go bad without being tripped?
Yes they can, a few have reported that.
Old Jan 17, 2015 | 02:22 PM
Stevaroo01's Avatar
Stevaroo01
Ok, so I got a test light, and I have tested both ye green w/ yellow) wire going into the intertia switch as well as the red (w/yellow) coming back out of it. I am not getting a light on either wire for any amount of time when I turn the key to the run position. So, what is ahead of the inertia switch in the system? Is there any chance that something in the key mech is causing the prob? How about the ECM? Could that play a part?
Thank you!
Old Jan 17, 2015 | 02:33 PM
subford's Avatar
subford
Note with the test you did the power is only on for one second so it takes two guys to do the test.
If you still do not get the power for one second with the above note each time you turn on the key then:
You need to ground pin #6 of the self-test plug and turn on the key. You should have power to the inertia switch all the time the key is on.
The self-test plugs location is noted in the diagram in post #9 above.
Old Jan 17, 2015 | 02:55 PM
Stevaroo01's Avatar
Stevaroo01
Thank you, I will give this a try. However, if you would be so kind as to answer one more ignorant question... How do I ground out the pin? I'm venturing into another area of no experience with this.
Thank you so much for your help Subford!
Old Jan 17, 2015 | 03:15 PM
Stevaroo01's Avatar
Stevaroo01
I just took a look under the hood so I could check out this self-test plug you were referring to. What I found was that the plug wasn't plugged into the protective plug on the fender but was just hanging in there. I don't know how long it's been this way (it wasn't very noticeable because it was kinda tucked under the lip at the top of the fender), but it looks like being unprotected has taken it's toll on it. Here's a pic of it:
It looks fairly corroded. Although the pin you mentioned to ground out for the fuel pump looks ok? In any case, what are the odds that the condition of this plug could cause a problem for the power to the fuel system?
Old Jan 17, 2015 | 03:53 PM
subford's Avatar
subford
You and stick a paper clip in it from #6 to #2. see image below.
Or you can run a jumper wire from pin #6 to the brake line at the master cylinder or the NEG post of the battery.
Yes it does.
Zero.
Old Jan 17, 2015 | 04:13 PM
Stevaroo01's Avatar
Stevaroo01
Yes it does.
Zero.
Thank you Subford! That was easy enough and when I tried it I got the light! I also heard the fuel pump start up. I tried both tanks and could hear both of them hum. Sadly, she still wouldn't start.
Based on this info, what is likely going on here?
I greatly appreciate you taking the time to help me troubleshoot this!
Old Jan 17, 2015 | 06:48 PM
subford's Avatar
subford
Sounds like a bad computer.
OR a computer without getting a good ground at the fender body ground by the battery (image below).
Old Jan 17, 2015 | 07:06 PM
Tedster9's Avatar
Tedster9
Yikes! Whoever's truck THAT was musta had trouble.
I disconnected the battery and cleaned those connections and ground points up and applied some NO-OX-ID, a conductive grease. Can't hurt.
Old Jan 17, 2015 | 07:15 PM
Stevaroo01's Avatar
Stevaroo01
Thank you again Subford. I will check the ground, and if that doesn't solve it, I'll look for a new computer. You mentioned early on in this thread when I mentioned that I smelled something like antifreeze that it sounded to you like a computer letting go. So, that very well may be what's going on here.
I'll let you know how it goes.
Old Jan 17, 2015 | 07:24 PM
subford's Avatar
subford
As to why the engine will not start more than likely the fuel injectors are not being fired (grounded) by the computer and the computer may be holding the SPOUT in a high state so you would not have any spark either if that is the case.
Old Jan 22, 2015 | 06:26 PM
Stevaroo01's Avatar
Stevaroo01
Well, I got the ecm computer replaced. It was a little more of an acrobatic experience than I thought it would be (thankfully I had a buddy who could lend an extra hand to help), but in the end the old one came out and the new went in.
I am thrilled to say that replacing the computer did the trick! My truck runs again for the first time in a month and a half!! Woo hoo!
After buttoning everything back up, I took the old girl for a celebratory spin around the neighborhood. It's been a long road the last few weeks with troubleshooting the no start problem, dealing with AAA braking the steering gear, etc. So it felt great to finally be able start, steer, and drive my truck again!!
A HUGE shoutout to Subford for all of his help and advice along the way!! I can honestly say that he is the reason my truck is running today!
Old Jan 22, 2015 | 07:36 PM
  #28
kaduh's Avatar
kaduh
Glad to see you got her running. I've been following along over the past few weeks.
Subford is the man! He's helped me out both directly, and indirectly over the years!
Whenever I need a schematic, I search: "Subford/whatever pic I need", and usually find it.
F250Rookie
Feb 20, 2018 08:50 PM
LuckyLobo59
19
Mar 27, 2017 06:26 PM
95_460
Feb 16, 2016 05:45 PM
Inline6Rookie
Jul 23, 2013 10:20 PM
ottoman96
29
Mar 17, 2010 04:19 PM
