Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
red brake warning light
Old Dec 7, 2014 | 08:48 AM
rob8210's Avatar
rob8210
I have a 2001 escape. The red brake warning light in the dash is on. I have changed the low brake fluid sensor and disconnected the parking brake switch . It is not on when first started but comes on shortly after starting to drive (within 100 feet). Do these things have a proportioning valve and a sensor in it?
Old Dec 7, 2014 | 10:52 AM
projectSHO89's Avatar
projectSHO89
Certain ABS faults will also turn on the red BRAKE light.
Does your ABS light prove out normally at key on? If no, that needs to be fixed for further diagnostics.
If yes, does the ABS light come on when the red BRAKE light comes on?
Old Dec 7, 2014 | 11:04 AM
rob8210's Avatar
rob8210
I was wondering about that, so I did some more investigating. Apparently a previous owner removed the ABS bulb, and the 60a power fuse and the 25a fuse. On the cover of the fuse box the fuse locations are covered over with a black dot.
GuitarJesus
Jul 18, 2017 03:48 PM
guitarmark
Nov 30, 2012 03:51 PM
strzbites
Feb 25, 2009 12:46 PM
lilbilli0naire
13
Jan 26, 2008 06:44 PM
DarrylT
Electrical Systems/Wiring
Jul 30, 2003 06:28 PM
