Clutch size
Old Dec 5, 2014 | 09:27 PM
gtcrackers's Avatar
gtcrackers
Clutch size
10 inch clutch? I have a 1960, 223, 3 on the tree, non synchro 1st. Most of the searches on this forum say a 10 inch clutch. However, I do see other sizes from time to time. Is there a number on the bell housing or tranny that will tell me for sure?
Thanks,
Old Dec 5, 2014 | 10:55 PM
hiball3985's Avatar
hiball3985
Thanks,
No way to tell that I know of. You will have to tear into it. I know mine wasn't a 10 inch but I don't recall now if it was 10.5 or 11..
Old Dec 6, 2014 | 01:23 PM
spurredon's Avatar
spurredon
The shop manual says 10 inch for a 2 wheel drive with a six cylinder but who knows what who ever has put in there over the years. The maunual also calls out an 11" for a 4x4!. Are you planning for replacement? Nice to get parts ahead of time but not always possible. Sounds like a shop manual should be on your list.
http://www.ebay.com/itm/like/130741227237?lpid=82
Old Dec 6, 2014 | 07:57 PM
gtcrackers's Avatar
gtcrackers
I have a shop manual. There was a ten inch set in it that I replaced. With everything back in place, the clutch fork is all the way forward (toward the front of truck) as it comes out of the bell housing. As a result it can't be adjusted on the rod. Can't get the 1/4 inch gap between the nut and rod unless it is almost against the slave. No free travel in the pedal. I was wondering if it came with a different size clutch, and the last owner had put a 10 inch in instead of what should have been in.
Old Dec 7, 2014 | 03:41 AM
willowbilly3's Avatar
willowbilly3
How did the new parts compare with the old ones? It sounds like you got a different style of pressure plate or the wrong throw out bearing. The basic diameter of the clutch would not affect the condition you describe.
Old Dec 7, 2014 | 11:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Dec 7, 2014 | 04:16 PM
gtcrackers's Avatar
gtcrackers
My transmission guy said that the new clutch and pressure plate matched the old. He did not say if the bearings matched. I had a clutch shop look at my parts and there was some question about the throw out bearing, but they finally decided it was the right one. I had some wear on the bearing hub and the fork, and I am waiting on those parts as well as a new release lever trunnions.
Dutter
Jan 1, 2012 01:40 PM
Tumblindyce
Oct 25, 2009 11:18 PM
Katmandu
Jul 22, 2004 10:35 PM
51dueller
Sep 2, 2002 09:04 PM
