Instrument Cluster Voltage Regulator???
Old Apr 6, 2002 | 03:50 PM
fordtman's Avatar
fordtman
Post Instrument Cluster Voltage Regulator???
Old Apr 6, 2002 | 07:41 PM
timjk's Avatar
timjk
I'm working on a 1987 F-250. Been having problems with low/irratic guages. Did some checks and decided to get a new IVR. Pulled out the instrument cluster and there is no sign of a IVR or a place to put one! Looked at a few manuals and wiring diagrams and they show an IVR. Does anybody know of a different location? Does this truck have a different system? This truck has a 460 with a carb and so far it seems to be a mix and match of the '87 and the '88 with fuel injection and diagrams not always jiving.
Any help appreciated.
Tim
Old Apr 6, 2002 | 11:11 PM
PAUL_2's Avatar
PAUL_2
Once you remove the instrument panel , It should be located on the lower left section of the panel , Its about 2 in long & and inch or so wide , it will have 2 , small screws holding it to the circuit board . Make sure its the cause of the problems , that little device is $75 .
Old Apr 7, 2002 | 12:44 PM
steve4413's Avatar
steve4413
I have an 88 460 and my oil pressure gauge reads low. When I rock my fuel transfer switch back and forth the oil pressure increases. Could this be caused by the regulator also?
Old Apr 7, 2002 | 01:06 PM
timjk's Avatar
timjk
Thanks for the reply, but here's the problem. I've had the cluster off and it's just not there! No place for it either. I've replaced a couple of IVR's on earlier model cars and trucks so I know what they look like. I did my diagnoses by connecting a 12 volt test light between the oil ppressure pigtail and a ground, and got a dim steady light. A good IVR should show a pulsing light. By the way, this has a "real" oil pressure sending unit.
I did some research and found that there is a IVR listed for this truck and can pick one up at NAPA for $25.00.
Tim
Old Apr 8, 2002 | 03:43 AM
cwmerc88's Avatar
cwmerc88
I have a problem with the oil pressure gauge also, except mine is reading way high. The truck (1990 F150 4X4 302 auto) originaly had no tach, so I purchased a instrument cluster with a tach out of a (1988 F250 460). The gauge read correct on the original cluster. Could the regulator be the problem because I really do not want to spend $125 on new oil and gas gauge. THANKS
73stang
Oct 21, 2016 09:21 AM
Hawkmcgee
Aug 24, 2013 01:12 PM
Guilmettedon
Electrical Systems/Wiring
Aug 7, 2003 10:02 AM
Wstrombe
Sep 21, 2002 05:52 PM
CRJ900
Jan 18, 2002 01:22 PM
