Clutch issue or ??
Old Dec 5, 2014 | 03:04 PM
martinraz's Avatar
martinraz
Clutch issue or ??
I have a 1973 Ford F-250 Camper Special, Manual, 360 V-8. When shifting, more often than not, the engine revs and does not engage to the next gear, even though I have depressed the clutch pedal to the floor etc. Usually happens when going up a slight incline, but have noticed it occasionally on the flats. Do I just need to have the clutch adjusted/replaced, or is there something else going south?
Thanks.
Old Dec 5, 2014 | 03:20 PM
hickory1991's Avatar
hickory1991
Can try adjusting. If that doesn't work, time for a clutch job.
Old Dec 5, 2014 | 04:36 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If revs because you push on the gas....it is probably a habit like double clutching it lol, yes I would try adjusting it 1st.
Old Dec 8, 2014 | 11:31 PM
myutesux's Avatar
myutesux
using a lot of brake fulied in chutch resouve
HI sorry to take over post but need help as will. And can't get help with my problem my question is I 'am using dot 3 brake fluid in chutch resouve when I fill it to top and press down a few time it seem to come back ?easier shifting After it uses a bit of fluid it pushes nearly to the floor and then shift is hard to do have i broke a seal it leaking from gear box line how to fix it would be the question
Old Dec 8, 2014 | 11:49 PM
HIO Silver's Avatar
HIO Silver
Install a mechanical clutch linkage. Problem solved.
StephenK
Feb 20, 2023 08:21 AM
green84f150
Jun 9, 2007 02:11 AM
jrtoy
1997 - 2003 F150
Mar 30, 2006 01:07 PM
nebi
Apr 13, 2004 08:57 PM
sethro
1983 - 2012 Ranger & B-Series
Oct 15, 2002 02:03 PM
