Adding passengers absolutely decreases payload!
Read page 246 2013 manual or under load carrying.
Steps for determining the correct load limit.
Absolutely it does indeed. As does anything else you add. Full tank of fuel... fifth wheel hitch... tools... The ONLY way, as stated over and over, to get your real payload is to weigh your truck ready to tow and subtract that weight from the GVWR. The payload number on the sticker is 100% useless.
Okay from the manual.... Steps for determining the correct load limit:
1. LOCATE the statement"the combined weight of occupants and cargo should not Never exceed xxxkg or xxxlb". on your vehicles placecard.
2. Determine the combined weight of the driver and passengers that will be riding in your vehicle.
3. Subtract the combined weight of the driver and passengers from xxxkg. or xxxlb.
4. The resulting figure equals the available amount of cargo and luggage load capacity. And so forth.
The payload number is vehicle specific. PLEASE just read
the manual!
Wrong, wrong and wrong.
The published payload includes passengers at each seat belt location. It is not practical for the shopper to weigh a truck. . .that advice is only good for owners that already have a truck.
A quick and dirty way to determine payload WITHOUT weighing the vehicle is to look at the tire rating printed on the side of the rear tire(s). It will be within a hundred pounds or so of the "payload number on the sticker".
Actually, right, right, right. What an extremely foolish and ignorant reply. So, you're saying the the actual weight of the truck has nothing to do with payload? LOL. Really, LOL. What a clown response. The payload number on the sticker is COMPLETELY USELESS and can be very different from the actual payload which can OF COURSE, only be determined by weighing the truck.
. . .So, you're saying the the actual weight of the truck has nothing to do with payload?. . .
Nope. Not at all.
I've posted no such thing.
In fact, if one is in possession of a truck, the proper method would be to weigh the truck and subtract the truck's weight from the it's published GVWR.
I guess when I said to subtract actual weight from the GVWR and you posted "wrong, wrong, wrong" I misinterpreted... OK, so you posted that if one was not in possession of the truck that they should trust the sticker listed weight which #1 has nothing to do with this thread and #2 would completely mislead the buyer. Good work.
