When I had the cluster out, I looked all the dash wiring over and it looks like everything was connected and intact. I couldn't see anywhere that the harness had ever been cut into.
After checking the fuse I will put a meter on the hot wire at the motor to make sure the switch is good, otherwise it would have to be the motor.
