EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Ecoboost losing power
Old Dec 4, 2014 | 10:59 AM
oilfieldanchor's Avatar
oilfieldanchor
2013 F-150 4X4 Ecoboost missing and shuttering like running out of fuel. Fuel pump module and filter considered lifetime service. Truck has a little over 100K miles. Anybody have any knowledge of concerns on Ecoboost.
Old Dec 5, 2014 | 07:36 PM
KCBS Smoker's Avatar
KCBS Smoker
Have the plugs ever been changed?
Old Dec 10, 2014 | 07:31 AM
Gregorri's Avatar
Gregorri
Could be timing chain stretch. Mine did the thing you describe before my chain was replaced. Google Ecoboost timing chain stretch. My was done at 98 000km
Old Dec 10, 2014 | 08:36 AM
senix's Avatar
senix
I would look at the plugs and the coil packs.
Old Jan 3, 2015 | 10:44 AM
boudroman's Avatar
boudroman
Has it only happened when it is cold and wet outside? If so, your intercooler is getting water in it which causes your turbo to shut down draining virtually all of the power to your engine. This is a problem with the ecoboost, almost got me killed a few days ago when I need the power and got none.
To fix it, take it to the dealer, tell them the problem, they will install a deflector on the intercooler and re-program the PCM to eliminate that problem (hopefully)
Old Apr 4, 2015 | 06:33 AM
BuzzLOL's Avatar
BuzzLOL
. Computer tuning the EcoBoost for vastly more usable power:
Truck Tech: Classic Chevy/Modern Ford - PowerNation - Full Episode | SPIKE.com (skip to 3rd segment of video)
Old Apr 5, 2015 | 09:29 AM
BuzzLOL's Avatar
BuzzLOL
. See the big EcoBoost FAILURE thread...
Old Apr 5, 2015 | 08:51 PM
jaxf250's Avatar
jaxf250
Same just happened to a buddy on another forum. He saw low pressure readings between 3rd&4th gears while datalogging. He replaced the in-tank pump&filter module and problem seems to have been fixed after about 250 miles testing post-replacement. Before this he had the timing chain replaced but that did not solve the low power problem. The new fuel pump did. Maybe this is your issue too?
Johnnynobody
Jan 25, 2016 06:36 PM
tcbofade
Jul 21, 2008 09:19 AM
klatt_89
Kansas Chapter
13
Oct 30, 2005 12:43 AM
Chrisvte
1978 - 1996 Big Bronco
Jan 6, 2003 09:02 PM
